Old 11-11-2004, 06:25 PM
jerm781
oil on top of motor
I get a little pool of oil on top of the motor. It leaks down the back of the motor and on to the exhaust pipes. I can't figure out were the oil is coming from. It looks like its coming from the bottom of the intake manifold but I don't think oil is supposed to be in there. Any suggestions. I was going to ignore it because it never reaches the ground but the smoking is embarrassing.
Old 11-11-2004, 06:28 PM
It's possible it's leaking from around the IRIS valve which is attached to the bottom of the intake manifold.
The oil is likely coming through the PCV valve which is located right behind the IRIS valve.
Old 11-11-2004, 07:14 PM
jerm781
I replaced the PCV valve,maybe I need to replace it again. It was leaking before and after I replaced it.
Old 11-12-2004, 05:21 AM
Maybe the infamous O-Ring Power Steering leak......50 cent fix, if thats what it is....
Old 11-15-2004, 09:36 AM
drivemusicnow's Avatar
Poor College Racer
what color is the smoke thats coming out? is it kinda white-bluish like oil is, or just grey like ATF fluid is?
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 11-15-2004, 06:32 PM
I had to re-read your post...my brain kept thinking that our oils are not that color...ATF is red.
Old 11-15-2004, 09:03 PM
RobSVX
If its Red...
It's probably P/S fluid. I thought my 'O-ring' was bad in the pump, so I replaced it and cleaned up...still happened.
Found out its the High Pressure P/S hose. The connector where it goes metal to rubber. Had to order one and the 3 lower hoses (to be sure).
Old 11-16-2004, 03:19 PM
The Molinator
HIGH PRESSURE PS HOSE!?
I just had my HP Power Steering hose leak and be replaced ....after I thot it ("oil" on top of engine) was oil from leaking valve cover on that (rt) side!
Check your P/S fluid level!
Jim
