Old 10-24-2004, 12:50 AM
TorG0d
"popping" or clicking when turning
At first I thought this was caused from warped rotors, but I just replaced them and the problem still exists. Basically, whenever I turn, it sounds like something is popping or clicking from the passenger side wheel assembly. It is probably not the CV axle as this was just replaced less than 15k miles ago, and the problem existed before then. I understand I'm being kinda vague, but that's all I got. Speed does not matter except for the quickness of the clicking or popping (i.e. the faster I go, the faster the clicking.)
Any suggestions would be appreciated.
TorG0d Fransisco Domingo ANdres Sebastian D'Anconia
Old 10-24-2004, 08:38 AM
n00b on demand's Avatar
I used to get a knocking noise when turning the wheel and i ended up getting the entire axle replaced and it went away.
Old 10-24-2004, 10:16 AM
Htownsvx Htownsvx is offline
Send a message via Yahoo to Htownsvx
that is how it started on my svx when ever i would turn i would get a nasty humm or a tick and it turn out to be the right front cat.
Old 10-26-2004, 11:06 AM
Peach
Re: "popping" or clicking when turning
Check your upper strut mount. Some have said their stabilizer. Mine pops too, I know it's my strut mount but haven't fixed yet...I driven it 5k miles like this I'll fix it in the spring...probably
Old 11-04-2004, 12:03 PM
RobSVX
Sounds like a CV joint.
Old 11-05-2004, 12:39 PM
Mr. Pockets's Avatar
Moderator
Axle.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 11-09-2004, 12:27 PM
svxsubaru1's Avatar
yeah it really sounds like a half shaft. You should test it by taking a pretty tight corner with no gas, then take the same corner not flooring it, but giving it a decent amount of gas and if it pops this time its the half shaft, if it pops both times i have no idea.
Old 11-09-2004, 10:29 PM
if it is continuous, buy new shafts, if it does it once after the wheel is turned it is ur strut mount. my mount is shot and it makes more of a pop than a click of a cv joint.
