Old 10-20-2004, 02:56 AM
SVXXX
question about 18' rims
I want to get these rims but i want to make sure they will fit ok.
its 5/114 with a 45mm offset. anyone have this size rim ? does it ever scrape or rub( with or without people in the car? . I want bigger rims but not sure if 18s are to big.
thanks
Old 10-20-2004, 06:17 AM
SVX_MY_BABY's Avatar
This wheel offset calculator courtesy of "lee"
http://toy4two.home.mindspring.com/offset.html
Old 10-20-2004, 10:26 AM
AFBeefcake's Avatar
Subaru Swapper
Those wheels should work as long as there not too wide . I run 18 X 7 wheels with 42mm offset and I have no rubing.
2005 Legacy GT
My WRX's Cardomain Page
Old 10-20-2004, 12:22 PM
SVXXX
fitment
ok heres what i got,
anyone know if this will work???
thanks guys
The clearance from stut housing to the inside of the wheel will be 4mm MORE
The outside edge of the wheel will EXTEND an extra 16mm
Old 10-20-2004, 12:43 PM
AFBeefcake's Avatar
Subaru Swapper
Sounds like those wheels will rub on the rear fender.
Mine are 7mm closer then stock and there only about 5mm from the fender.
2005 Legacy GT
Old 10-20-2004, 02:38 PM
If you run 42mm offset and have no problem, then the 45mm offset should be better. Yours extend 3mm more than the 45's. As long as you tires are not too wide I would think they should fit.
laryiii has a tire calculator in his locker.
http://www.subaru-svx.net/photos/fil...yIII/14768.xls
Old 10-20-2004, 03:10 PM
AFBeefcake's Avatar
Subaru Swapper
Re: fitment
Originally posted by SVXXX
The outside edge of the wheel will EXTEND an extra 16mm from stut housing to the inside of the wheel will be 4mm MORE
I think the rims he's looking at are wider then 7"
2005 Legacy GT
Old 10-20-2004, 05:34 PM
NapaBavarian's Avatar
Good morning!
I gaurantee you that 18 foot diameter wheels will not fit...
.Karl.
Old 10-20-2004, 11:06 PM
SVXXX
Ok I found rims I want but I have a new question.
These are 18 x 7.5 with 40 mm offset. sound ok?
and the guy said They come with 12mm x 1.5" lugs. I would have to buy the 12mmx 1.25 lugs locally he said. Will that work ok? are hey alot of $$$$?
thanks guys!!!
Old 10-20-2004, 11:13 PM
SVXXX
I got this from the tire calculator on those above rims I want.
any suggestions?
The clearance from stut housing to the inside of the wheel will be 9mm MORE
The outside edge of the wheel will EXTEND an extra 21mm
Old 10-21-2004, 05:47 AM
Ok
and the guy said They come with 12mm x 1.5" lugs. I would have to buy the 12mmx 1.25 lugs locally he said. Will that work ok? are they alot of $$$$?
thanks guys!!!
That is the correct size nut. You can buy them at most tire shops or parts stores. Can be cheap or expensive depending on your taste in style & quality of plate. Suggest you buy a locking lug for each wheel.
Old 10-21-2004, 02:40 PM
SVXXX
Rims on hold
Thanks for all your help people!!!!
But Now I have to wait till spring to get my rims or my wife will say "no more punany for you"
Old 10-21-2004, 02:52 PM
Re: Rims on hold
I'm sure she'll miss you
