Old 10-17-2004, 08:26 AM
StooKer StooKer is offline
tweeter not functionning
Hi!
My tweeters is not working. When I purchased this SVX one year ago, the door speaker was destroyed. Could the tweeter have been also damaged? I have looked at the tweeter and they seem fine to me. What I can check next? The radio?
Thanks!
Old 10-17-2004, 09:56 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Given the way the door speakers dry out, it wouldn't surprise me if your tweeters have done the same. There are plenty of sources for replacements out there.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-17-2004, 10:10 AM
How can I check if the tweeter get a signal from the radio? A voltmeter will work?
Old 10-17-2004, 07:40 PM
SVXRide's Avatar
Try a multimeter - I'd check the resistance first to see if you've got an open or closed circuit.
-Bill
Old 10-17-2004, 08:12 PM
lee lee is offline
the OEM tweeters have the Xover at the tweeter itself, so the lines going to the door and to the tweeter (in the kickpanel) are full spectrum...so, got any other kind of speaker (like home stereo or computer) that you can plug into those lines & see if there's output. The reason I suggest this is a voltmeter response might be misleading given the wide frequency range and dynamics of typical music. If you don't have a speaker to use and want to use a voltmeter, then if you have a CD-burner, make a track with just one frequency (say 1000Hz) - that way at least the meter will have something stable to average.
Old 10-17-2004, 08:15 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
yeah basically what lee said .........you won't get a standard "4 ohm" reading from the meter - actually it'll probably be extremely high ......you just have to test em out with another source that you know is outputting some juice.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 10-18-2004, 01:04 PM
SVXRide's Avatar
Lee,
I understand what you're suggesting. Wouldn't the multimeter still tell him whether the circuit is open or closed?
-Bill
Old 10-18-2004, 01:21 PM
lee lee is offline
Originally posted by SVXRide
Lee,
-Bill
yes, but I thought (maybe my bad) he's also looking to see if there's radio output on that channel. I have no idea what "good" output would look like, so that's why I suggested what I did. You're absolutely correct to see if the speaker circuit is still intact.
