Old 12-04-2001, 08:14 AM
deligeds
Question Slowly failing alternator?
I think my alternator is starting to go bad, but I wanted to get some confirmation. Here's the deal:
The engine was frequently slow to crank when starting, especially after lenghty drives. The weird thing was that it wasn't "slowly cranking", it was either not turning over or cranking at what seemed like full speed. I could turn the key and . . . nothing. Try again . . . nothing. But if I held it at start for a few seconds, it would finally turn over and start right up. I thought maybe it was a wiring thing, except for the eventual cranking when held at start. Anyway, it eventually wouldn't turn over at all. Suspecting my old battery, I got a jump (started right up), promptly went to the auto parts store, and replaced it. A few days later, I again noticed that it was slow to turn over after long drives. Sounds like alternator, right?
Old 12-04-2001, 10:28 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Uhhh...
...there's nothing like paying someone $15 to check out your starting & charging system. It could have already saved you the price of a battery. It may also save you the price of an alternator...
Beav
Old 12-04-2001, 10:50 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Uhhh...
Beav
Not to mention MOST chain autoparts stores (Autozone, Advance Auto, etc) will check your charging system for FREE.
Randy Johnson
Mike Davis -- at Reading VI
Old 12-11-2001, 11:49 AM
Lowered SVX
go to the dealer......
have the check and see how many amps the alternator is putting out. i think it is supposed to put out 13.5 or .7, cant remember. usually when mine is about to go bad it is putting out under 13 amps.
anyway they can check and it is real simple to know if it is or isnt putting out enough power. it should only take like a minute for them to check for you.
"Too much fun to drive!"
Old 12-11-2001, 02:33 PM
craigk
pulley
Just a note: I thought I had a bad alternator, even replaced it. Found that the crankshaft damper pulley was slipping. It looked normal, but with the belt off, I could spin the pulley on the rubber.
Old 12-11-2001, 08:41 PM
immortal_suby's Avatar
Thread Killah
Crank Pulley
That is now the 6th time here I have heard of a crank pulley disintegrating. 5 are from '92s and one '94. Chris, Sk8ing19, blonde-man,Nvrmore, listed, and now craigk have all had them come apart.
I think I'll get an aluminum underdrive set and put it on the shelf the next time they go on sale.
Locker Link
2015 BRZ Limited 6MT
Old 12-18-2001, 02:47 PM
Lowered SVX
i will have to check that out next time...
before i run out and replace my alternator. thanks for the info. guys.
Old 12-26-2001, 07:57 AM
northernkanuck northernkanuck is offline
You can add another to your list of pulleys coming apart. Although I no longer have my SVX I had the same problem about 2 yrs ago.
Old 12-26-2001, 06:48 PM
MoreIBNR MoreIBNR is offline
Original Owner 1992-2008
Send a message via AIM to MoreIBNR
1984SubaruSVX - Don't you mean "volts" and not "amps?" I sure hope your alternator is putting out way more than 13.7 amps!!!
