Old 11-25-2001, 06:36 PM
SVXtc
Directions for water pump
What do I need to do to replace my water pump? Instructions ect...
Old 11-26-2001, 11:11 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
John & I recently did my timing belt/water pump and photographed the procedure. I plan to put that together with the shop manual instructions and a list of parts including special tools (right John?) and gaskets for a complete guide.
The problem is I haven't found the time yet to write it up.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 11-26-2001, 11:26 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Doug
Don't forget instructions on how to give your engine that "pretty pink glow."
Randy Johnson
Mike Davis -- at Reading VI
Old 11-26-2001, 11:40 AM
mohrds's Avatar
<<Don't forget instructions on how to give your engine that "pretty pink glow.">>
That is a custom off road application I do not recommend for daily drivers
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 11-27-2001, 01:12 PM
SVXtc
Do you have to pull the engine out to get to the timing belt? About how long did it take you to do both things?
Old 11-27-2001, 01:28 PM
Aredubjay's Avatar
You do not have to pull the engine to get to the timing belt. The water pump is a simple operation once you've cleared the way to the timing belt. That's the reason it's probably best to change it while you're there (unless you know it has recently been replaced). Most of the work (I think) is invested in getting the pully off. Doug can fill you in better, since I haven't actually done it, I just read about it in The Road and Track Guide --- Um, I mean, the Service Manual. But, can't completely recall the procedure. At any rate, no, you don't have to pull the engine.
Randy Johnson
Old 11-27-2001, 01:53 PM
mohrds's Avatar
<<Do you have to pull the engine out to get to the timing belt?>>
No but removing the radiator is about the most removal other than the involved parts themselves
<<About how long did it take you to do both things?>>
We also installed a new radiator, transmission cooler, replaced all the hoses and belts and that took us about 5 hours I think. If you just replaced the timing belt and water pump, I would say for a first timer, plan 3-6 hours. If you buy the pulley wrench, cut an hour off of that. If you buy the sprocket wrench as well, subtract another 45 minutes.
I don't have those tool part numbers handy, but I will get them tonight so someone can price them up.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 11-27-2001, 09:21 PM
mohrds's Avatar
Crankshaft Pully Wrench 499977000 $171.06
Camshaft sprocket wrench 499207100 $0.00
I beleive they are both discontinued. Perhaps NAPA or some other parts store can get one for less $$$
Doing the job without them is possible, but plan on a lot of swearing.
Doug
1994 LSi (4/93)
2000 Ford Excursion
