Old 02-20-2005, 12:26 PM
rob_4187's Avatar
rob_4187 rob_4187 is offline
You're mine!!
Send a message via AIM to rob_4187
Well since i had to remove my exhaust system to change my flex plate i figured i might clear out my primary cat if its a good idea. Are there any ill effects to this? Will it free up some hp or at least sound deeper? Thanks
Teal 92 SVX LS L with 103k
Engine: Stage 1, 3 in filter with heat sheild, underdrive pulley, NOS fogger system (75 shot)to be installed soon Sound:1 10" infinity with 230 continuous watt Dual amp (we have small trunks)
Old 02-20-2005, 01:10 PM
deruvian
Well, it will sound rattley and have a slight buzz to it (at least that's what I've heard from others that have done the same).
Old 02-20-2005, 01:27 PM
rob_4187's Avatar
You're mine!!
If it is completely clear is shouldnt rattle (unless there are loose bolts) ... but i've never heard it on a svx before so i dont know.
Old 02-20-2005, 04:53 PM
deruvian
Talk to some of the members that are running no cats. Most will tell you that there is a slight buzz/rattle at specific RPM ranges. I know that you're not running without all the cats, but by removing the innards of the primary (I'm assuming that you mean the 2>1 cat) you will probably have a little unwanted resonance.
Old 02-20-2005, 08:44 PM
rob_4187's Avatar
You're mine!!
Do you know of any hp increases?
Old 02-21-2005, 10:42 AM
deruvian
I never seen anyone post any resolvable before and after results. All I know is that it can increase your ponies a little, but reduce your torque as well.
Old 02-21-2005, 02:37 PM
rob_4187's Avatar
You're mine!!
So is it worth it? Is the torque loss greater than the hp gain? Also, i am hooking up nitrous in a couple weeks if it makes a difference.
Old 02-21-2005, 04:49 PM
deruvian
If you are absolutely sure that you are installing NOx in a few weeks, then by all means, remove/destroy the cat. Freer flowing exhaust is usually good with NOx, especially since the first cats are so close to the manifold. I would actually recommend removing/destroying those ones, unless you need to pass emissions. If so, do the next best and remove/destroy the third cat.
Old 02-21-2005, 07:55 PM
rob_4187's Avatar
You're mine!!
I have the system and i am going to install it as soon as i get some body work done. I heard that clearing the precats will mess with the O2 sensors which could be potentially harmful. Florida emmisions are easy to pass....we dont have an ozone anyways. Will i gain more hp and lose more torque by clearing the pre's? I am pretty certain in clearing the main cat but i dont know if i should mess with those.
Old 02-22-2005, 05:40 PM
rob_4187's Avatar
You're mine!!
Well there have been quite a few precautions from most people so i think im gonna leave them and eventually get high flow cat and magnaflow exhaust later. I'll just have to spray and not get the full effect...
