Old 03-10-2004, 01:19 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
Hella Supertone Horns, installed. *pics*
Just test fit my new horns. Sorry stock grillers...this wont work for you. I used the bolts for the hood latch. Fits perfectly.
Doing the wiring some time this weekend.
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 03-10-2004, 03:35 PM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
That's gonna be loud as Hella!
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 03-10-2004, 03:37 PM
Old Fogey
Looks great Scott! After trying the Hellas on my Legacy with and without the relay, (used stock twin horn wiring), I'd encourage you to go to the extra work using the relay and 14-16ga wiring. Volume was incrementally louder. You'll love it the first time you chase someone back where they belong with those "fire-breathers"!
Glenn
Old 03-10-2004, 03:52 PM
Mr. Pockets's Avatar
Moderator
Or Hella loud.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 03-10-2004, 05:15 PM
Bwana's Avatar
*Special* Member
Glenn
How does the relay hook up? The instructions that came with them basically say: Plug in the positive, plug in the negative. That's all.
Do I take the power off the stock wires, and just extend the wires to reach the horns?
Old 03-10-2004, 05:27 PM
lee lee is offline
I like it.
I'm also intrigued by the grille. Did you notice any gain/loss in cooling by dumping the stock piece? How do you have the mesh attached? Is that stainless, Alum, or ??
Old 03-10-2004, 06:27 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Like I said in your PM, check the amps on the horns and your Horn fuse (either under the hood or the kick panel).
If the new horns draws lower amp, you are set. Connect the + to + and - to - side of the horn. I don't think they are labled. So It should not matter. However, if the new horns' amp draw is larger, you are going to trip the breaker and blow the fuse.
Use a relay. Relay is nothing more than a switch. It'll have 2 + and 2 - terminals. Power and switch. Power goes to the current horns and switch to the new horns (or is that the other way round). I can tell you if I see it in person.
Lwin M. Maung (Member # 147)
Current SVX: • NONE
Other current cars:•2001 Jeep Grand Cherokee Black
Old 03-10-2004, 08:06 PM
lee lee is offline
The wiring diagram I have shows the OEM horns driven by a relay. Seems you could simply extend the original wiring up to the new horns. Am I missing something here?
Old 03-10-2004, 08:16 PM
Old Fogey
Scott, You'll need to use the existing horn lead as the "actuator" and tie it to terminal 86 on the relay. Pin 30 of the relay goes to (+) terminal on the battery (fused of course!). The horns should be well grounded (to their mounting points) and the horn "hots" go to pin 87, and 85 goes to Ground as well.
lee and Lwin, the light gauge wire is the downfall of the OE wiring, so it's best to pull fresh battery source straight from the Battery. Or, maybe yours truly is just being anal about the whole thing!
Glenn
Edited for clarity, and safety! Thanks Lwin!
Old 03-10-2004, 08:49 PM
Seraph's Avatar
Scott, You'll need to use the existing horn lead as the "actuator" and tie it to terminal 86 on the relay. Pin 30 of the relay goes to (+) terminal on the battery. Now I can't recall, and didn't mark my diagram, which Subaru does, push (+) or (-) to the horns, but the horns should be well grounded(to their mounting points) and the "hot" goes to pin 87 and 85 goes to Ground as well.
Glenn
I agree with you there about OE wire being too thin. When I did mine, I just hooked them directly to the OE wires without any trouble.
But If you can I always recommand a relay and a fuse. Safer that way.
Current SVX: • NONE
Old 03-11-2004, 07:55 AM
here is the link to the Hella Supertone horn specs: http://www.rallylights.com/hella/supertone_horn.asp
Click HERE to see the wiring diagram using a relay.
Stock horns typically have an output of 97dB. The decibel scale is logarithmic and therefore the sound pressure doubles for every increase of 3 points, i.e. a horn with 118dB is approximately seven times as loud as a stock horn.
Old 03-11-2004, 06:52 PM
Bwana's Avatar
*Special* Member
I did the wiring today. I didnt use the relay. I cut off the connectors of the stock horns, and extended them with 12ga wire long enough to reach the horns. I use 12ga wire to ground them.
They sound very similar to stock horns, except 10 times louder. They are awesome. And I got to use them right after I finished! There's a stop sign right by my house that people rarely stop at. Of course, when I pull up to the sign, some idiot on his cell phone blows right through the sign. I lay on the horn, and he dropped his phone because he was so startled!!
Soo awesome...I recommend everyone upgrade their horns.
Old 03-11-2004, 07:35 PM
Seraph's Avatar
How do they sound compare to mine? I am trying to get a hold of electronic horn. Once I get them, the current ones on mine goes to the galant.
Current SVX: • NONE
Old 03-11-2004, 08:05 PM
Bwana's Avatar
*Special* Member
They sound more...high pitched. They sound like they fit the car. Yours sounded like they would come from an F-150 or something.
Old 03-11-2004, 08:49 PM
Seraph's Avatar
Cool. I'd have to hear them.
Current SVX: • NONE
