Re: Failing aftermarket fuel pumps
I am going to try and find it tomorrow.
Spark, Fuel, Air ... 1. You've confirmed the engine turns over 2. Pull the fuel line from the fuel filter to the fuel rail -- crank and confirm that you've got fuel pressure 3. No fuel pressure - pull the back seat bottom and check to see if you're getting voltage at the pump when the key is on 4. Voltage good? yeah, replace the pump 5. No voltage? start back tracking the circuit 6. Good Fuel pressure at the fuel rail? start checking your sensors that will prevent correct spark events -- temp sensor, crank sensor, cam sensors -- you're looking for the correct resistance across each sensor. If you're lucky and can acquire them, replace them - one at a time - checking to see if it will start after each replacement. Good luck with it! Bill
It's under the football shaped metal cover held in place with four phillips screws.
Be sure to check the ground side as well. Have seen a lot of fuel pumps fail from bad grounds. Increased physical resistance will cause higher amperage draw but increased electrical resistance will decrease amperage draw. A pump that draws too little burns out. Don't know why but it seems to happen.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
Got it running again. Hopefully it stays running....
What cured it?
Not entirely sure. I cleaned the connector receptacle contacts. It was still not wanting to start. For some reason I told my kid to floor it and try one more time. It started and stayed running. I was able to start it a couple more times tonight with no issues. It idles great.
Sounds like the pump had to pressurize the system
