Battery swap - SVX to Infiniti G35
The battery is shot in my G35, and since my SVX is dead right now, I was wondering if i could use the battery from it. It's a higher rated CCA than the infiniti but close.
I have an Everstart Maxx 24 (770 CCA) in the SVX, and the infiniti calls for an Everstart 35N (640 CCA) Other than that, the batteries look about the same in size, terminals, etc. Anyone know if it would work okay to change over? Just curious before I go out and drop the $$ on a new battery.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
Re: Battery swap - SVX to Infiniti G35
CCA doesn't have any effect on battery application. As long as it fits you're good to go. I always stuffed the biggest battery I could find into the SVX. Think I had 850 CCA at one point...
However, now that my car is a summer only vehicle I want this battery: http://shop.antigravitybatteries.com...ries-ytx12-24/ 720 amps from a lithium motorcycle-sized battery. It weighs 5 pounds. Five!!! My Optima was 35 or 40 pounds.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 09-29-2014 at 08:48 AM. |
Weight reduction comes at a premium price.
Cool, I just didn't want to inadvertantly fry something in my Infiniti if the battery was more power than it was expecting.
as long as its 12V and fits, you're good to go. you want highest CCA you can get .... well i do, anyway .... we get snow. if you're in Texas, probably not that important. just get one that meets or exceeds the manufacturer's recommendation.
Alan 1987 928 S4 (Black) SOLD! 1997 SVX LSi (Ebony) SOLD! 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! 1987 928 S4 (Black) SOLD! 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) |
Hey Alan! Good to see you still around. I didn't think you still hung around here anymore.
I tried the SVX battery but the posts were on the back and so the Infiniti cables wouldn't reach. I ended up going to COSTCO and got the OEM battery from them. It was $30 less than the 24F (posts on front) battery so I went with the OEM instead. It's 560CCA instead of the 780 that the 24F was but it seems to work just fine. You're right, here in TX we don't get that kind of weather so its not as critical. I don't plan on having the G35 much longer anyway so why spend the extra $$
i wouldn't say i hang around here - i just pass through from time to time.
Thread Tools | |
Display Modes | Rate This Thread |
