Old 04-11-2007, 12:51 PM
etz bseder etz bseder is offline
Sorry 'bout the hijak
I have the same problem, and that sounds like what I need is the ecu temp sensor. How do i find it, that picture is a little too close up. Also where would i find the part/how to replace it. What is the part #?
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit.
Next changes ... PAINT, fix engine problems, 4.44. (GONE)
'97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE)
Old 04-11-2007, 02:05 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
The temp sensor is on the drivers side of the engine towards the back. Its alittle under the intake and is fairly easy to replace.
Dustin
-Dustin
Old 04-11-2007, 11:10 PM
Part
Any idea on where I can get one, and/or a part number?
Old 04-12-2007, 01:18 AM
odepaj's Avatar
Killer of threads
You can get one at probably any parts store, or your local stealership. It'll most likely run between 10-20$ (I got mine from Subaru for like $12).
Dustin
-Dustin
Old 04-12-2007, 03:55 PM
odepaj's Avatar
Killer of threads
Where is our fuel filter? I've been looking around but cant seem to find it. I also saw in another thread someone saying if the timing was off the engine would crank faster? Mine seems to be faster than normal so more and more im thinking its the timing belt slipped.
Dustin
-Dustin
Old 04-12-2007, 04:30 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
The fuel filter is under the hood right next to the drivers side strut tower.
Old 04-12-2007, 04:36 PM
odepaj's Avatar
Killer of threads
Thank you, (I actually found it 5 mins after posting and now I feel kinda dumb for not seeing it). So i've deffinetly got fuel, im almost possitivly sure its the timing belt, how do I go abouts fixing this?
Dustin
-Dustin
Old 10-11-2012, 11:26 AM
BRZCory BRZCory is offline
Re: Problem starting
Damnit, need to know how this was fixed!
Old 10-11-2012, 11:44 AM
BackWoodsBob BackWoodsBob is offline
Fool your ecu into thinking it's in neutral all the time, cory. Should be relatively easy to give it the signal it's looking for for neutral. That'll eliminate that possibility at least.
Old 10-22-2012, 09:10 PM
odepaj's Avatar
Killer of threads
Sorry, I never came back and finished this thread. The problem ended up being the (nearly new) platinum spark plugs would give me spark but were fouled enough to apparently keep the engine from running.
I put in some nice iridium plugs and the car started right up and has been running perfectly ever since.
I hope this helps anyone having similar problems.
-Dustin
