Re: Engine Oil Temperature
No idea,don't have an engine oil temp gauge,all I know is that it takes water from the water pump,circulates around the modine/oil filter then returns the water to the block.
THAT is the best hit I have heard this week!
Funny man.
However, when I brought my 85 quattro out of storage and drove it into the shop the EG33 started running on five cylinders. Then, when I brought my wife's Mazda in for a service at started running on four. Only after I parked it next to my 4.0 Cherokee did it start running on six cylinders again. Maybe there's something to your theory. |
Just out of curiosity, what would you like to see your oil temp. at?
'92 SVX LS Pearl White - 6mt |
I'd like it to stay below 250F during and between autocross runs. Right now it's nudging 250 on the freeway at 75 whcich makes me think it will get much hotter during events in the summer. Gauge stops at 250F so if it goes off the gauge I can't tell what it is.
I'm curious now: What are typical oil temps like for other cars/engines?
What would it take to add an oil cooler to a US model? Do we need a special water pump? Is there a plugged port in the block that would need to be removed so the coolant can make a complete circuit?
It's going behind the slots I cut in my front bumper: |
