Old 04-27-2011, 07:52 PM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
First Issue with my '96 in years - Misfire in 3 Cylinders
My old Auto XRay EZ Link is displaying P0302 Cylinder 2 Misfire, P0304 Cylinder 4 Misfire, P0306 Cylinder Misfire.
She was running great as she always has and today, at a red light, she sputtered, flashing Check Engine, solid Chek Engine indication. Ran badly for a few hundred yards, started running as great as always then did it again a mile later.
Engine has 188K, new Iridium IX 2 months ago. I have a few ideas about what the problem may be, but could use some experienced opinions!
Dave W.
______________________________
1996 Redd
Old 04-27-2011, 08:18 PM
Re: First Issue with my '96 in years - Misfire in 3 Cylinders
Timing belt might have jumped a couple teeth on on cam.....since they are all on one side of the motor...
Old 04-27-2011, 08:25 PM
wynndi's Avatar
I had considered that, but, after the 1st and 2nd occurrence, she ran fine...
Definitly worth looking into deeper.
Dave W.
1996 Redd
Old 04-27-2011, 08:26 PM
Just throwing ideas out, but the igniter, ECU, cam sensor, crank sensor, moreso the first 2 than the latter.
Old 04-27-2011, 08:32 PM
Check the grounds on the fuel rail on that side
Old 04-28-2011, 10:13 AM
wynndi's Avatar
I don't see a grounding wire, but will try to check for continuity.
Any other ideas?
Dave W.
1996 Redd
Old 04-28-2011, 10:40 AM
MAF or faulty spark plug wires??
