Old 04-25-2008, 06:32 PM
Ken92SVX Ken92SVX is offline
Strut mounts
I have a 92 SVX with the typical noises/popping noise from the front end.
How hard is it to replace the strut mounts and how is it done?
Thanks, Ken
Old 04-25-2008, 06:47 PM
SomethingElse's Avatar
word words wording
not bad if you have a spring compressor, air tools, and a lift. check your swaybar links for play as well...grab the swaybar and pull up and down to check for play.
Eric
Old 04-25-2008, 10:14 PM
I did struts and mounts my and marisa's svx's. other than that I have done maybe 100+ cars. My svx was easy, but hers was harder for some reason. to errr on the safe side here is what had to be done on her car.
Quick and easy way that will need an alignment afterwards is as follows:
jack up car
remove wheels
remove top hat covvers (platic things)
remove the 3 strut mount nuts (on each side)
remove the bolts for the brake lines and abs unit (3 on each side)
don't un do the brake hoses from the caliper though
remove the 2 large bolts on the spindle/strut interface (on each side)
remove the strut/spring assembly (on each side)
use spring compressors to compress the coil spring (on each side)
then undo the 1 nut on the strut shaft (on each side)
your strut mount is now free to replace
do the reverse to get back together
I am not good at being descriptive so hope this helps a bit.
Have fun and don't hurt yourself.
blk 92' LSL w/ average mods
Old 04-26-2008, 06:31 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Originally Posted by SomethingElse View Post
not bad if you have... a lift.
Struts? A lift?
Old 04-26-2008, 06:25 PM
Spring compessor?
Thanks to all who replied!
Where do I get a spring compressor or can I rent one from some where?
Ken
Old 04-26-2008, 08:31 PM
autozone does free rentals.
Old 07-28-2009, 04:35 PM
svxash's Avatar
svxash svxash is offline
Re: Strut mounts
So I'm going to replace mine and went to Subaruparts.com to check on the parts. Do I only need to replace the strut mount(20320) or are there other parts I should get as well?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 07-28-2009, 06:59 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Strut mounts
I would get #20321, its a foam bumper that usually gets toast.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 07-28-2009, 08:05 PM
svxash's Avatar
Re: Strut mounts
WOW! That piece is $20.93 ea.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 07-28-2009, 08:52 PM
Green1995SVX's Avatar
Re: Strut mounts
I've never seen one of those go bad on an svx. ??
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 07-29-2009, 04:06 PM
Re: Strut mounts
Mine were shreded on the rears when I did my springs. They were dry rotted and fell apart.
Seth
Past subies:
Other toys:
Old 07-29-2009, 04:12 PM
processengr's Avatar
Re: Strut mounts
+1 I installed new struts, front and rear on both our 92s , both dry rotted...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 07-29-2009, 06:38 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Re: Strut mounts
I must say this is a very helpful thread. I will be replacing the front strut mounts late this summer.
1995 Subaru Svx L / AWD
Old 07-30-2009, 09:27 AM
alia176 alia176 is offline
Send a message via Yahoo to alia176
Re: Strut mounts
subscribing...good info when my time comes
If it ain't broken it, doesn't have enough features!!!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
