Old 09-18-2002, 12:46 PM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
Ok folks I got the metal master pads and raceconcepts slotted rotors and their SS Lines. So far the metal masters are great @ $34/set.
Here are the links:
http://www.brakewarehouse.com/axxis.asp
http://www.raceconcepts.net
If you want EBC Greenstuff pads you need to order front pads for the '93 Pathfinder order the EBC SUV pads which are the same compound as the EBC Greenstuff IIRC.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 09-18-2002, 04:27 PM
oab_au oab_au is offline
Re: Re: Re: jamsvx
Originally posted by mattski
Harvey, by "Radial vented", do you mean the type that is on the front but not the rear?
Thanks as always,
Hi Matt, yes the front, with the vents that run from the center to the outside edge. The holes leak cold air into the vents producing local cold spots that cause surface distortion.
One Arm Bloke.
Tell it like it is!
