Old 12-18-2008, 04:12 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
DDM HID's Not Working
K so I bought the Apexcone 35W kit 'cause both headlights were burnt but they aren't working. I remember driving around with 1 burnt light for awhile and then the second burning. I'm wondering if it's possible my second headlight didn't actually burn out but there's some other malfunction. Is there a fuse for the lowbeams? Anyone have any advice and/or suggestions.
I have a spare 9006 bulb so I'm going to put that in real fast to test out if it works but I'm posting this now so I can hopefully get some feedback to read when I come back from work.
Old 12-18-2008, 04:17 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: DDM HID's Not Working
I think thiers a fuse under the hood. But i'm not sure.....
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 12-18-2008, 04:23 PM
processengr's Avatar
Did you reverse the plug into the ballast? This is necessary on the DDMs
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 12-18-2008, 07:03 PM
IceBlade's Avatar
I'm not sure what you mean. If I remember correctly it's connected like this:
The light has two plugs which feed through the weather seal and plugs into the ballast. The ballast then has another wire attached to it, which plugs into the extension wire, which feeds back through the weather seal and that is the connector I plugged into the lowbeam plug.
One more thing. Did anyone use the weather seal? 'Cause it doesn't seem to fit anywhere.
Edit: Didn't have time to test the regular bulb yet. I'm still at work
Edit2: Aha! I forgot about the reverse thing. So what do I have to do? Can I just reverse the wires on any connection? If I pull the extension cable out and reverse one end's wires that will do?
And one last thing.. would putting it in normally wreck the lights? :S
Old 12-18-2008, 07:16 PM
immortal_suby's Avatar
Thread Killah
just unplug the connector, flip it over, and plug it back in.
I reversed mine the first time and it didn't wreck them.
Locker Link
2015 BRZ Limited 6MT
Old 12-18-2008, 07:43 PM
IceBlade's Avatar
Couldn't wait any longer so I went out and flipped the connectors. They work! Thanks a lot, guys. Hopefully the boss didn't see me out there :P
I'm still wondering as to weather or not anyone used the weather seal that came with the kit and if so how did you go about installing it?
Old 12-18-2008, 07:52 PM
Ownbot's Avatar
Ownbot Ownbot is offline
I'm the anti-do-gooder
The weather seal and the extension cable I just cut off. I think thats what everyone else did to.
Old 12-18-2008, 09:11 PM
I also cut off the seal but used the extention cable to mount the ballast behind the fender.
Seth
Past subies:
Other toys:
Old 12-20-2008, 08:36 AM
IceBlade's Avatar
On the passenger side I mounted it where the ABS would be. I've got a FWD, unfortunately. On the drivers side I mounted the ballast behind the fuse box.
I'm delighted with these lights
