Old 12-11-2008, 08:52 AM
knowtion knowtion is offline
Used Tires on Rims ?
I have read that it is bad to buy mix matched tires for the SVX, but what about buying used rims on used tires assuming the tires are all the same and reletively evenly worn?
Old 12-11-2008, 08:59 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: Used Tires on Rims ?
I don't see why not! People buy used rim/tire combo's all the time! If you notice a difference, like one is bald and the rest are 7/10 then yeah it's a problem. Otherwise, not really.. Just make sure they are the right size for your vehicle or you'll end up with problems...
Old 12-11-2008, 10:47 AM
paulmeisterpk's Avatar
paulmeisterpk paulmeisterpk is offline
Sconnie
Send a message via MSN to paulmeisterpk
Just make sure they are ALL the same tire size, and ALL the same tread depth. If they are, you should be fine.
Old 12-11-2008, 01:32 PM
On subaruoutback.org they suggest that all tires be within 1/4 inch of each other in diameter. I measured my mixed snows with a soft measuring tape wrapped around the middle and all were under a 1/4" different.
Old 12-11-2008, 05:43 PM
kwren's Avatar
kwren kwren is offline
if they are directional, make sure that is correct!
keith
