Old 05-01-2008, 11:31 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Originally Posted by Maxo View Post
Just out of curiosity, should my power light still flash after the fwd fuse is inserted?
AFAIK Inserting the fuse just tells the TCU to set the duty cycle to 95%. If the problem is still detected, then the light will still flash.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 05-01-2008, 06:56 PM
Trevor's Avatar
Trevor Trevor is offline
Originally Posted by b3lha View Post
It's hard to understand, but I think there is just one signal to check the solenoid state. I don't know which position, closed or open, the signal represents. Furthermore, I have no idea how the state is detected. Perhaps, as you say, it is by measuring inductance.
To be absolutely precise for you: If we assume the signal indicates "closed/not closed", then the error condion is that (a) The solenoid is energised but the signal says "closed", or (b) The solenoid is not energised and the signal says "not closed". Obviously if the signal indicates "open/not open" then the opposite applies.
Phil.
Sadly Phil, you are confirming my suspicion that the claims made within the manuals, may have originated via the sales department.
If you uncover any more clues, please keep this posted as the matter is quite important and can lead towards frustration in fault finding. Your reasearch is much valued and very worthwhile.
Trevor, New Zealand.
