Old 07-10-2006, 09:21 AM
DanSVX94's Avatar
DanSVX94 DanSVX94 is offline
Ren-Ma Osu
Want grey driver's door sill and ...
A) Driver's side door sill -- as long as the mounting tabs are intact
B) Cig lighter outlet -- mine doesn't have power
C) 1 or 2 of the gray nut/washers that hold the rear spoiler.
D) I also don't know if there's a small cover that covers the opening on the passenger side of the trunk that covers the thin vertical opening to access the tube for rear washer fluid.
E) Last item is the piece of plastic that's about 4 inches wide that sits on top of the steering column and also goes over the turn signal.
Please pm me if you have any of these.
Old 07-10-2006, 10:11 AM
B) Cigarette lighter: You probably blew the fusible link in the base of the lighter. You will have to take out the lighter assembly and either put in a new one or replace the fusible link with a piece of copper wire. I did that a couple of years ago with no problems since. Here is a link to the threads on removing the lighter.
C) the spoiler nut you need us Subaru P/N 902600009. Goes for about .40 each
http://www.subaru-svx.net/forum/sear...earchid=139705
D) There is no cover that goes over the thin vertical opening. I guess you are supposed to be able to see the washer tubing and use it as some sort of a gauge of how much washer fluid you have. The only two covers that remove inside the trunk are the curved gray plastic doors that cover the tail light/turn signal bulbs.(see attachment)
Old 07-10-2006, 10:42 AM
Check your inbox.
Old 04-03-2008, 11:20 AM
SuberNatural SuberNatural is offline
Anyone know what happened to the link? I needed to try that to fix my cigarette lighter for my radar det.
Thanks
