Old 05-08-2007, 06:31 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Go to Subaruparts.com, and go under engine, you will have a whole list of engine parts including hoses with numbers.
Old 05-08-2007, 06:46 PM
etz bseder etz bseder is offline
Thank you, that worked very well
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit.
Next changes ... PAINT, fix engine problems, 4.44. (GONE)
'97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE)
Old 05-08-2007, 07:46 PM
immortal_suby's Avatar
Thread Killah
Originally Posted by dannmarr
I replaced some vacuum lines with hoses I bought from an auto store and they all cracked within a few months. I just ordered all new hoses from Subaruparts.com
hmm... didn't have a problem (that I know of) with the auto store hoses that I used - maybe it's time I checked under there again - its been a few years.
Locker Link
2015 BRZ Limited 6MT
Old 05-08-2007, 08:28 PM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
Off the topic a bit, but what kinda symptom do you see when those vacuum hoses are bad..?
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
Old 05-08-2007, 08:43 PM
I started with a code for the O2 sensors, and changed the spark plugs and now it's just the old symptom of code 34 and rough starting sometimes. You might also have a lot of engine shaking when missing one (happened to my legacy)
Old 05-08-2007, 08:58 PM
Thread Killah
If you've never replaced them, they are most likely bad. Those things shatter like cheap wine glasses if you poke at them. Remove the intake and they will surely snap.
Locker Link
Old 05-09-2007, 07:29 AM
dannmarr's Avatar
I work for my SVX
Some of the Subaru hoses are preformed and hardened. This prevents kinks and withstands the heat from the engine.
Old 05-09-2007, 09:23 AM
dcarrb dcarrb is offline
Are you talking about vaccuum lines, or pre-formed hoses? In my 30+years of driving I've never known of generic vacuum line to crack within a few months, or years, for that matter. That stuff you got must have been of very poor quality.
If you need a pre-formed hose(s) like the crankcase ventilation hoses pictured above Subaru is probably the only source. For generic vacuum lines, ATF hose and such, I'd bet the quality of aftermarket goods equals or exceeds what comes from a dealership.
dcb
Old 05-09-2007, 09:44 AM
dannmarr's Avatar
I work for my SVX
I replaced both hoses from the PCV connection, the small hose that connects to the shift kit and the short L hose under the snorkel part. They all cracked at the connections. You may be right about the cheap quality. But I'm not taking chances again, unless it's a temporary fix untill I order Subaru parts. The prices won't break me. Anyway, I sure don't want to replace the PCV hose that goes under the manifold again, what a PIA!!!!
Old 05-09-2007, 10:22 AM
I'd like to know the reasoning behind the location of the PCV valve on these cars. Seems to me they could have put one in each of the valve-train breathers. No, wait... then they'd be too easy to clean or replace.
dcb
