Old 04-19-2007, 01:04 PM
SVeXy96's Avatar
SVeXy96 SVeXy96 is offline
Sold my soul to Subaru
Unhappy Scary Brakes! Yikes!
Ok so everytime I brake my whole car shakes. It used to be only a little bit bad. I thought maybe my rotors were super warped. I replaced front and rear rotors and pads. Now when I hit the brakes the car shakes VIOLENTLY! If I relax my head I look likeone those bobble heads you put in your dash. And my steering wheel is visibly shaking (jerking about and inch left and right, but not enough to actually turn the car) Its much worse the faster I'm going and the harder I'm braking. Under 40 mph it doesn't happen at all unless I have to make a sudden stop. Could they just be out of balance though. It seems like its coming more formt he front and not the back end of the car. When I did my brakes I put both rear wheels in a solvent tank and used a wire brush to scrub the almost 1/2" crud built up on the inside of my wheels. I was painting my calipers that day too and it was taking forever so I didn't clean the front wheels. Could something that small be my big problem? ANy suggestions?
Old 04-19-2007, 01:06 PM
JaySVX's Avatar
JaySVX JaySVX is offline
Have you checked alignment, do you have a bent rim by chance? that could cause such symptoms. I know the feeling your talking about, my alignment is off, but i'm waiting for new tires to get it fixed.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 04-19-2007, 02:27 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
My guess is your control arm bushings. If you jack the front end up, get a pry bar between the control arm and the subframe. There should be some movement front to back but none from side to side. There are two bushings per arm, check them both.
Old 04-19-2007, 06:08 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Check Alignment, bent rim, wheel balance, frozen caliper.
Old 04-19-2007, 06:18 PM
Trevor's Avatar
Trevor Trevor is offline
In an effort to prevent confusion as a result of many ideas, I confirm agreement with the above.
It has been stated that the problem is confined to braking, which means that torque is involved, surely thus ruling out tyres, wheels and steering geometry.
Trevor, New Zealand.
