Old 04-04-2007, 06:46 AM
Clydesvx Clydesvx is offline
Way over-the-hill Member
Fuel gauge finally died
Well after only 267,000 miles my fuel gauge has found a resting spot below E. Has anyone replaced their fuel pump and gauge sending unit? How much trouble is it? Should I just continue using my trip odometer to determine when to fuel up!!
'92 LSL TEAL 277,000 miles
Trans (on # 3) Engine (on # 2)
"NEW" VISORS
'03 Forester XS 214,000 miles
'05 Outback 3.0R
Old 04-04-2007, 08:43 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Fuel pump shouldn't have anything to do with it, but that's the easiest to replace. I would guess it's either the sending unit or the guage itself. The guage you can replace, i would get a donor instrument cluster from a wrecked car, personally, as OEM would be a nightmare. Also you could get an aftermarket fuel guage and mount it somewhere. The sending unit i'm not sure where it is, but you can check it with a multi-meter to see if it's good or not, via some wires in the dash or under it.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 04-04-2007, 09:02 AM
Manarius's Avatar
Manarius Manarius is offline
I would say it's the sending unit contacts being corroded. That's the way it usually is on the Legacys. The replacement of the sending unit requires that one remove the fuel pump from the car. Unfortunately, they usually just corrode up again.
-Jason
-Obi Wan Kenobi
Old 04-04-2007, 10:20 AM
davew833 davew833 is offline
I've replaced the fuel pump and sending units together-- it's not tremendously hard. It helps if you have the replacement beforehand to see how it fits together since the whole assembly has to fit down into the tank through a 4" hole under the back seat. It's kind of like building a ship in a bottle. The good news is that the pieces clip together on a hanger inside the tank, and that it's all done from inside the car-- no need to drop the tank or get under the car.
davew833@yahoo.com
Former 6-time SVX owner
Old 04-04-2007, 05:06 PM
Dominus's Avatar
Dominus Dominus is offline
Homo Sapien Superior
Wow! It only made it to 267,000 miles...you should really complain to Subaru. Those bastards!
Old 04-05-2007, 06:20 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
I agree with Jason.....I had a legacy also and the sending unit does corrode, my gauge would act funny every now and then.... Also check your battery terminals and clean off any buildup with a wire brush.
1995 Subaru Svx L / AWD
Old 04-05-2007, 12:33 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
J shows the location of the sensor
- John
Old 04-05-2007, 12:40 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Does the gauge work sporadically? Then the contacts are going bad.
Or is it just constantly below "E"? Then I would guess the gauge itself or a broken wire along the way.
Old 04-06-2007, 07:43 AM
Thanks for the input folks. I guess I'll check the wiring first then if all else fails I'll try to replace the pump and sending unit. At least I won't have to drop the tank. I did the same job on an '88 bronco. That was a bear.
"NEW" VISORS
'05 Outback 3.0R
