Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 02-25-2007, 11:43 PM
Good N/A Exhaust setup (vid clip)
This is a link to a video clip of Shotgunslade's ehxaust system. I will wait for him to give the particulars of the system and where to get it done. Sounds GREAT in person and this clip in no way does it justice, but it will give you a good idea. The tone while driving is also very different and much deeper. This system is not raspy at all.
Shotgunslade exaust clip
Old 02-26-2007, 02:09 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Send a message via AIM to Ricochet Send a message via MSN to Ricochet Send a message via Yahoo to Ricochet
I'm impressed..
(aka, get me an estimate )
Brian
Old 02-26-2007, 03:23 AM
Ricochet's Avatar
I brought some ham.
If possible get a video of him driving. I want to hear it under load at full throttle.
Brian
Old 02-26-2007, 05:55 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
All of the information is in the thread below. It was built by Mufflex in Hamilton, NJ, using their components and Dayle's tips. The muffler is a Bullet, Camarao-style. The system, less tips, cost about $800, as I remember.
http://www.subaru-svx.net/forum/show...hlight=exhaust
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
