Old 04-13-2005, 09:07 AM
914helo 914helo is offline
Refreshing my engine
I picked up the below engine out of a 92 LSL with just over 60K on it for my project. It's pretty clean and looks to be in great shape, and the timing belt looks almost brand new. However, it's been sitting for close to 5 years. What do you all recommend I change on it? I figured some of the seals may have dried up. I already have a new waterpump and seal, and thought about getting a new thermostat and gasket, and crank and cam seals. How many are there? Thanks for you input.
Kent
Old 04-13-2005, 09:22 AM
Mr. Pockets's Avatar
Moderator
I'm pretty sure you can buy a whole kit of engine seals from Subaruparts.com. That'd certainly be more thorough than just guessing at a few seals to replace at random.
Edit: Yup. I just looked, and here's the kit: http://tinyurl.com/4uyvt
For the money, I'd just do that. Hell, the engine's out of the car anyway. It doesn't get any easier to replace seals than that.
I'd get an engine stand, though. They're not expensive.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-13-2005, 10:17 AM
Thanks for the quick reply, and yes I'm currently looking into buying an engine stand (have to have the chief of finances approve it ). I don't know if I want the entire seal kit because I wasn't planning on replacing all of them. Maybe while the engine is out I should anyways?
Kent
Old 04-13-2005, 10:23 AM
Moderator
Again, that's what I'm getting at. I mean, if you just want to replace the seals that are obviously leaking, that's your call. But I figure, as long as the engine is out of the car, why not replace all of them?
As you said, who knows what's dried out since the engine has sat? For all you know, when you put that engine in a car and start it up, oil will pour from every seal it has.
2005 Outback
END OF LINE
Old 04-13-2005, 10:51 AM
dcarrb dcarrb is offline
In addition to gaskets and seals, I'd go ahead and spring for a new set of plugs. Check the timing belt tensionsers for any hint of noise that may indicate corrosion on the bearings. No matter how new it looks, that timing belt is at least five years old, and I'd replace it. And I'd change the oil and filter several times in the first few hours of operation. Five years is a long time for an engine to sit.
dcb
Old 04-13-2005, 11:02 AM
I already ordered 6 new PFR6B-11 plugs and pulled the old ones (looked very good). I also planned to change the oil, then after I get it to run for about an hour, I'll change the oil and filter again. I had a different engine sit for 3 years before and when I got it started it leaked a tiny bit so now I'm a little paranoid. Maybe I'll just take some extra time and replace all the gaskets. I'm so impatient
Kent
Old 04-13-2005, 11:04 AM
immortal_suby's Avatar
Thread Killah
I just did this with an engine that sat for at least a year.
Timing belt
Front main seal
Cam seals
Vacuum hoses under intake
PCV valve
Spark plugs
rear main seal
Oil pump
Water pump
Exhaust gaskets
Thermostat
power steering pump O-ring
Valve cover gaskets
Remove and clean intake and IRIS valve
Clean out EGR pipe
Oil change a few times - might even need to run some engine cleaner in it to clear up passages (mine ticked/clattered until I did this)
Engine stands are only about $50 and will make it eleventy billion times easier to work on the engine.
Locker Link
2015 BRZ Limited 6MT
