NEED HELP FAST!!! look please
i need a scan of probably page 84 and 85 of the svx service manual... i have a legacy one, and the part of the manual that i need is section 3-2 (automatic transmission and differential)
REMOVAL AND INSTALLATION 1. shift solenoid, duty solenoid and valve body i need this part, and i specifically need the part about removing the valve body as a whole, not in two pieces... i need to know which bolts to remove... they're different from the legacy
SV What? |
never mind, it was the same, the diagram was just weird looking
rant: when you make a diagram for something in sequential order... if you removed a part from the unit in a previous step, do not include that part in the diagram at a later point in the process the oil strainer pan was removed in step 5 (incl diagram on how to remove it) step 6 was remove the control valve body, in the diagram the oil strainer was still pictured, with bolts needing removed being pointed to behind theoil strainer!!!
SV What? |
Always glad we can help
