Tps
Does anybody know how to check the TPS. I believe I've found it (on driver's side of engine by throttle body?) but I don't know how to access the wires to measure the resistance. Any suggestions?
Mat-1
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
Re: Tps
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
Re: Tps
I matched marked mine and took it out. Then I check the resistance. But this is hard to do also. You are looking for the slightest change in resistance that is not consistant with the motion of the sensor. I am buying a new one to run a comparison. |
Re: Re: Tps
Did your idle speed change? |
I'm confused
I'm pretty lost here. I haven't done anything. Will turning the TPS adjust the tranny to eliminate any sort of shudder or just slippage. I'm not sure I understand just how it works. I know that it is a variable resistor, and I understand what you're saying about looking for any un-smooth changes in resistance, but I don't understand how it affects shudder or slippage or anything.
Re: I'm confused
http://www.subaru-svx.net/forum/show...0&pagenumber=1
