Old 10-31-2009, 03:22 AM
Pierre-Olivier's Avatar
Pierre-Olivier Pierre-Olivier is offline
Automatic transmission fluid ?
Hello, which transmission fluid for my SVX, Motul Multi ATF, Motul dexron II-D or Motul dexron III ?
Thanks you...
Old 10-31-2009, 03:29 AM
scoobymal's Avatar
Re: Automatic transmission fluid ?
Mine seems to like Dexron 111
Old 11-01-2009, 09:03 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
AMSOIL synthetic ATF
1995 POLO LSI 76K MILES SOLD
Old 11-01-2009, 09:44 AM
Hello, the transmission fluide, MOTUL DEXRON III is good for my SVX ?
Thanks...
Old 11-01-2009, 09:51 AM
Amsoil may not be generally available in the south of France.
Old 11-01-2009, 09:55 AM
Thanks...
Yes Pierre, that's a good oil.
The main thing to be careful about is mixing oils with a mineral base with oils that are fully synthetic. That's generally not a great idea.
In other words if your gearbox is filled with mineral oil then use the same sort of oil to top it up.
If you have it filled with fully synthetic, then stick to fully synthetic when topping up.
Old 11-01-2009, 09:58 AM
Yes, ASMOIL is not available in France !
YACCO ATF DEXRON III is good ?
Old 11-01-2009, 09:59 AM
O.K, thank you for answer me, i pay !
