power steering
I have a 92 svx that has a slight shudder while doing slow tight turns. High speed is good, around town is good, fluid looks good. It happens when I'm turning into a parking spot, right or left. I haven't noticed it backing up. Also, the more I drive the car, the less noticeable it is. Sometimes I leave the car sit for a week or two. Then it's really obvious.
Greg |
Got the procedure. the car is going into the garage for a timing chain next week. I'll try it then.
Thanks. Greg |
I smell Torquebind, not power steering problems.
Where is the shudder?
It feels like it's in the steering to me. The belt looks good, no cracks or obvious wear and the tension feels ok. I also plan on replacing the s-belt when I replace the t-belt* (Thanks Ensteele, I actually knew this as I just ordered it and plan on changing it out myself. Hopefully the car will run again).
Torquebind? Hmmn, that smells much more expensive. Perhaps I should investigate this. So, the plan right now is to change the fluid (I'll use the turkey baster method), the reservoir O ring, and the s-belt. Is there anything that I can do to determine if torquebind is the culprit? Greg |
While you are in doing the T belt, I would also replace the water pump.
Yup,
I've got a new radiator, hoses, water pump, thermostat, crank and cam seals, t, s, and alt belts and a bunch of gaskets. Should be interesting. I've got my fingers crossed about the ps res o ring. I looked around for info about the torquebind and found Tom saying: "It's ALIVE!!!! The new tailshaft has fixed all ailments. My guess is that there was an abstruction of the transfer valve in the old housing which would not allow it to actually cut the line pressure. I know the Sol. C was working but the transfer valve was not." Greg |
How about putting the fuse in for front wheel drive only and seeing if it's still happening?
1999 Audi A8. No more SVX's for now. |
