Old 06-19-2008, 07:00 PM
BlackMKIV BlackMKIV is offline
Scary SVX
ok, So, I need a awd vehicle, I look on the net and find an SVX within an hr of me for sale, I think 'sweet', always liked the way they looked. it's a 92 Touring package, 165k miles, guy wants 3,450.... (lil used car dealer). I'm thinking about offering 27 or 28 for it and seeing if he'll deal any... So, I call in to work today, after getting a carfax from some very nice guy on this site.
Cars clean on the fax
off I go. Get to the dealer, and this SVX doesn't look bad at all, lil paint issues on the hood and peeling front bumper, but hey, to be expected. he brings out the key ( no remote), and I open up the door, truck and hood.... begining my inspections, inside is good, better than expected on the leather, all console parts are there, but the steering column only locks in the lowest position. Good so far right... here where it gets fun. the car hasn't been moved/started in so long that it has rust growths growing off of the brake disks, in fact I couldn't even make out the wear marks in the disks anymore, all 4 of them. He'd cleaned the motor up pretty nicely on top, but when I wedged my head up in under the from wheel/ bumper area... whew man, enough oil under there to lube a fleet, everything was soaked, and total grimmed up, control arms, and axles and stuff just soaked in old oil. I could get in to the rear diff, and took a look at it, it had leak marks around the seals, and the rubber bushing on the backside top where 2 bolts go in.. they were completely shot, almost nothing left.
And then I started it, or well, then he put a jump pack on it and I noticed that the FWD light was on. I asked, he didn't know. So I checked the glove box and read the owners manual and we pulled the fuse. finally I started it. it actually ran, and ran reasonably ok. I was kind of proud of the old girl. No strange noises, no rattles, no valves hammering, at least from inside. then I turned on the climate controls... LOL. the car jerked, and the AC pump attemtped to spin up, and when it did it struck up a conversation with anyone will to talk to it. Not only that but the AC pump and the motor didn't get along.. leading to me having to rev it some to keep the motor and the pump working at the same time. whew. eventually it calmed down..... some. and I was able to drive away. yes I drove it, I traveled almost 1hr 45 mins total to get to it.
I had to make a 9 point turn to get out of the parking place. and the car wouldn't back up on it's own (automatic trans) had to goose it to go backwards. Finally pulled out onto the road and got moving, and it didn't do to bad, had a nice wobble in the wheel from the disks, and almost no stopping power, but I knew from the shape of the disks to expect that. When I'd try to go, it'd shift real jerky from 1st to 2nd, then 3 was a lot smoother. I didn't go above 50. We got back to the dealer and pulled in and stopped... as it stopped and big cloud of oil smoke rolled out of the passenger side front wheelwell...and I turned the car off.
the dealer looked at me and I looked at him, and we both knew that he didn't have a sale. He had no intention of lowering his price, and while I was still interested, I was well below 27 or 28 hundred now. in the end we decided that if he couldn't pawn it off on anyone else, then he'd sell to me, CHEAP.
BTW, you guys have a great community thing going here, and a wonderful car. thanks.
Old 06-19-2008, 08:11 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Re: Scary SVX
Firstly, with the trans acting up. Check the Fluid, it might just be low.
After it sitting for so long though you don't know what things might pop out later on down the road......
I'd say if you buy it, it should be under $2k.
Dustin
-Dustin
Old 06-19-2008, 10:20 PM
Re: Scary SVX
I know it needs Rotors turned if not new disks. pads would be a must... and from the looks of the bottom of the motor it'd need valve cover gaskets at least. with it not having been moved I wasn't sure if the Trans issues were from it setting for so long, or from something else. I've not ever driven one, so I don't know what to expect, in fact I've only seen one moving in real life once or twice.
I didn't check any of the fluids since the dealer really wasn't interesting in actually trying to sell it. I mean, hell, he didn't even make sure the Batt had a charge. but if he'll come down I'd like to own it. it'd make a nice secondary to my Prime car and prolly an ok winter car in Indiana, cos it's not like we get THAT much snow. hell I'd buy it for the rarity value alone if I could!!!!
Old 06-20-2008, 12:18 AM
Re: Scary SVX
Common oversight. There are 3 levers. How many did you attempt to operate?
Judging from your review, it sounds like the trans could be on it's last leg. The FWD fuse being in is a clue. Did you feel any binding or thumping in turns? If not it's possible your center clutch is already gone. Next time you head over there get under and do your best to get a look at the driveline to see if it's powering the rear wheels.
Or there is an easier way, goose the throttle and if your tires spin, AWD is gone.
Old 06-20-2008, 05:34 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Re: Scary SVX
I would hold out for another SVX unless the price is right, especially if this is your first one. Sounds like you're coming from a Supra, so things are a little different.
The rotors are one of the short falls of the SVX, so turning rotors that could already be too thin may result in them warping again.
Most of the common seal leaks are the front and main seal, valve cover gaskets and the rear seals. Since the engine is horizontally opposed oil can pool where the valve covers are making them more likely to seep. Seeping is common with the older ones but the car is still perfectly driveable in most scenarios but should be taken care of eventually.
The FWD is a potential red flag that there was transmission trouble, but as nikfu said, some of those symptoms could be low fluid. A transmission swap (either with any later model 94-97 Outback or Legacy 2.5L auto 4EAT or even 5mt swap with any late model subaru) has proven to be a tried and true method with positive results.
Good luck if you do decide to purchase it, but there is a large wealth of information and very supportive community to help keep these things on the road.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-20-2008, 06:15 AM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
Re: Scary SVX
Originally Posted by Tim View Post
I would hold out for another SVX unless the price is right.
Check the For Sale thread on the forum. You might find a nice SVX there if you do not decide to purchase this one.
To me, that price is much too high for the problems that this car seems to have.
Good luck!
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 06-20-2008, 06:43 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Re: Scary SVX
Welcome! It's to bad your first experience wasn't a shining one with the SVX. They're really great cars, but there's potential to have a lot go wrong with them. As heavy as the car is, rotor warpage is not uncommon. If you get new pads, I'd reccomend the ceramic pads, they are much less dusty, have good stoping power, and good life. Getting the motor resealed can be a timely job, and if you don't do it yourself, can be very pricy. If the shell is good, I'd go $1700~, with full intensions of having the motor and trans resealed/rebuilt/replaced right off the bat. Once that's done, it sounds like it would be a rather solid car. Good luck!
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 06-20-2008, 08:00 AM
92LSiLver's Avatar
92LSiLver 92LSiLver is offline
Re: Scary SVX
Ebay Item number: 180254282619
Old 06-20-2008, 08:24 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Re: Scary SVX
Look at the Laguna Blue 5spd for sale in here. Its a southern car and shouldn't have the rust issues of nearly all northern cars. Not that the SVX is prone to rusting, but as a minimum all underneath bolts are a PITA to work with on the northern cars. As with all cars, if not taken car of and washed regularly during the northern snows you know what happens.
I agree it sounded like you drove a $1500-1900 car depending on the final assessment of the tranny.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
