Old 07-21-2006, 11:14 PM
Sweet... Those are heavy guys aren't they?? Takes close to everything I got to lift one of those bad boys up on my own... I will see what I can get in the mail tomorrow, just shoot me your addy again VIA PM so I know for sure that I have it
Old 07-22-2006, 08:19 AM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
It was a challenge to get into my friends GTi. But now the tranny is sitting up where we're going to do the swap in a secure storage locker. Ship them parts ASAP, it usually takes 5+ days ground to get out here from the East.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 07-22-2006, 11:22 AM
GreenMarine's Avatar
From POST-***** to LURKER
WOW... this looks like a fun thread.... I'm watching to see how everything goes Good luck!!!
Old 07-22-2006, 08:29 PM
gest24's Avatar
#1 6MT In Cali
lol, Thanks for the support. This has been in the planning stage since March and now we're 2 weeks away from it happening.
RIP
84 VW Scirocco
02 WRX
Old 07-29-2006, 10:19 PM
Just a bump for anyone following... Kerry, I may have a nice surprise for you when I get there
Old 07-29-2006, 10:25 PM
gest24's Avatar
#1 6MT In Cali
uh oh... Cams? Konis? STi Seats? lol I'm going to post up pics of all your custom parts painted satin black. I was thinking, what are we doing about the brake booster?
RIP
84 VW Scirocco
02 WRX
Old 07-30-2006, 06:17 AM
ummm.... I figured we could do it there instead of flying one out... sorry forgot to mention that. I will be sure to pack the correct die for it. Sorry to keep you out of the loop on that.
Old 07-30-2006, 11:57 AM
gest24's Avatar
#1 6MT In Cali
Sounds good to me.I'm curious about this "surprise"
RIP
84 VW Scirocco
02 WRX
Old 07-30-2006, 01:17 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
+1, good luck for the swap.
looks fun. update us the progress.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 07-31-2006, 09:29 PM
gest24's Avatar
#1 6MT In Cali
I'm gonna take some pics tom of the newly painted pedal box, cross memeber, and assembled custom Shift linkage w/ Tom Stock Short Shifter.
RIP
84 VW Scirocco
02 WRX
Old 08-01-2006, 06:08 PM
gest24's Avatar
#1 6MT In Cali
Here's the Pedal Box and Short Shifter
RIP
84 VW Scirocco
02 WRX
Old 08-01-2006, 06:23 PM
You did the get the X-member right??
Old 08-01-2006, 06:30 PM
gest24's Avatar
#1 6MT In Cali
What X-Member?
JK... Its been painted and clearcoated. Check my homepage for more Pics.
RIP
84 VW Scirocco
02 WRX
Old 08-01-2006, 07:05 PM
shotgunslade's Avatar
Something to think about with the STI pedals. When they are mounted in the SVX with the stock positions for accelerator and brake, the two pedals are too far apart for heel and toe unless you wear EEEE shoes. That really doesn't matter unless you want to do track work. If you do, I would recommend having someone heat the accelerator pedal arm with a torch and bend it toward the brake pedal so it will be close enough for heel and toe work. Or maybe someone knows of an accelerator pedal sideward extension that would fill in the gap.
Old 08-01-2006, 07:47 PM
gest24's Avatar
#1 6MT In Cali
The Pearl prob won't see a track or Auto X course. Even if I would, it would prob be only once to try it out. But thanks for the heads up!
RIP
84 VW Scirocco
02 WRX
