Old 05-10-2006, 08:02 PM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
New Parts Installed; PWR rad, Perrin LCP
Installed my new PWR radiator today, and while I had the old one out, I dropped in a Perrin lightened crank pulley, since the OE one was coming apart and unbalanced.
It was kind of stressful for me, but I got it all in, and everything seems to be holding okay so far. It is a 65km commute home from the shop, so if nothing bad happened in that space of time, I'm guessing that I did everything correctly.
All was not sunshine and lollipops however. The rad is a tight fit; I had to really muscle that thing into position so that both top brackets fit on correctly. The hoses appear to be routed properly though; the top neck on the rad doesn't seem to be too long. The cap, on the other hand, may be causing a clearance problem... or it could have been the plastic top from the coolant bottle sitting in the way, I'm not sure yet. It closes ok with the stock cap now that I've moved the debris out of the way
The pulley went on just fine, and the wobble from the old unbalanced one is gone. One discrepancy came up though, and I'm not sure if I should be worried about it or not; the instructions from Perrin say to torque the retaining bolt to 90 foot pounds, but Ali, the journeyman who is teaching me, says that Subies should have 130 foot pounds on the crank pulley bolt. I went with the 90 foot pounds, figuring that the manufacturer of the product might know something that Ali doesn't.
If anyone has any thoughts on either of these issues, feel free to post them.
Well, so far so good, as I said. Temp gauge is right where it should be, and the Butt-O-Metre™ says that there is a little more snap with the lighter pulley.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 05-10-2006, 08:06 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
The Tourque could be lower due to the construction of the pully.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 05-10-2006, 08:23 PM
DanSVX94's Avatar
DanSVX94 DanSVX94 is offline
Ren-Ma Osu
What does the pulley do? Sorry for my huge ignorance.
Also, I thought the PWR radiator would be an identical fit. Is it too big? How did the old radiator look -- was it in good shape?
Old 05-10-2006, 08:29 PM
The pulley basically runs all your accessories off the crankshaft of the engine. The stock one weighs about 4 pounds and has a rubber insert to dampen vibration, and in my case, the rubber insert was coming apart, causing the pulley to wobble, thus putting undue strain on the crank bearings. The replacement one weighs 1.2 pounds, thus reducing rotating mass on the crankshaft. This allows for faster revving.
The PWR rad is a little larger than stock, and it could pose clearance issues. I think I got it to fit so the hood closes now, but I had to reuse the old cap. I will re-try the new cap soon and post my findings. Also, the upper mounting pins are a few mm wider than the stock rad, so the rad upper struts were tough to get in, but it does fit.
The rad is only 2 years old, an OE replacement for the one that blew a month after I got the car. It is going into my other SVX to replace the rad in it that blew a month after I got the car. Sheesh. Bad luck with rads, or what!
Old 05-11-2006, 10:23 AM
The FSM says to torque the crank pulley between 108 and 115ft-lbs. I torqued my aluminium one to 110.
Old 05-11-2006, 11:31 AM
intelisevil's Avatar
<<<Alcyone
It does make sense that an aluminum pulley would not want to be torqued as much as a steel part. The aluminum pulley could crack under too much pressure.
My PWR radiator came with an eight sided 'Stant' lever style cap and it works just fine. I still have to deal with the overflow outlet mismatch.
Dan
Old 05-11-2006, 04:47 PM
Well, after sleeping on it, then trying the locking cap they sent, it does in fact clear with the hood closed. I'm just retarded. Actually, I was just burnt out and not thinking straight (or at all) at the time. I'm better now.
Old 05-11-2006, 07:06 PM
immortal_suby's Avatar
Thread Killah
I agree - torque it down to subarus spec or you could end up with a nikfu'd pulley.
I have 2 svx's with an aluminium pulley on each that I torqued to the fsm specs with no issues and no problem of stripped out keyways. Crank that sucker down.
Locker Link
2015 BRZ Limited 6MT
