Old 05-09-2006, 04:12 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Wow Tom, your old SVX is on eBay.....
Wow Tom, it looks very much like your former SVX to me...
It's on eBay now? Are you gonna buy her back?
Anyway, you can verify this...based on the specs and everything,
it just makes me think it is your old SVX.
http://cgi.ebay.com/ebaymotors/Subar...spagenameZWDVW
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 05-09-2006, 06:21 AM
AppStateSVX's Avatar
AppStateSVX AppStateSVX is offline
Mountaineer
Send a message via AIM to AppStateSVX
wow, it does look like it, black engine and all
1992 Midnight Black LS-L - Sold 3/3/06
1991 Toyota MR2 - Sold 11/27/07
1992 BMW 325i
- Tokicko Suspension
Old 05-09-2006, 06:23 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
The seller didn't install Koni's and the new transmission... Tom did, if its his original car
Why are we all up so early?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 05-09-2006, 07:11 AM
yuppers thats mine!! That SOB dynoed it and didn't tell me. 191 AWHP baby, that is sick because he doesn't have the ECUtune stage 2 either. I cannot wait to get my new cams now. Maybe now that he is selling it, I can get the money he still owes me back
Old 05-09-2006, 07:31 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
I just saw that auction on Ebay as well and realized it was Tom's when I saw the rear quarter panel dent, the painted intake manifold and the Konis. He does have an SAFC-II installed in the car which was obviously tuned pretty well.
2006 Steel Gray WRX TR (sold)
Old 05-09-2006, 07:45 AM
Chiketkd's Avatar
Here's the dyno plot which I've saved to my locker (so it's not lost when the auction ends):
It looks like the rpm scale (which is partially hidden) runs from 2,000rpms to 7,000rpms, showing a peak power being reached at a hair below 6,000rpms. It also looks like the SAFC-II needs better tuning around that region in the rpm band...
Old 05-09-2006, 07:46 AM
DarknessofDeath's Avatar
Inhabitant of Darkness
owes you money? why dont you just take the car back straight
Old 05-09-2006, 08:02 AM
Tim's Avatar
Tim Tim is offline
And give it to me!
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 05-09-2006, 09:52 AM
Speedklix's Avatar
Locker Link Solution
funny, it echos like mine... black, 5speed, rotors, with ugly right front and rear corners... I want koni and those wheels. I was going to get drop springs, but after seeing this I think I want GC too!
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 05-09-2006, 12:25 PM
mbtoloczko's Avatar
sans SVX
Looks like there are two dyno runs on the plot. What's the difference between the two?
Mychailo
Visit my locker
Old 05-09-2006, 02:26 PM
Chiketkd's Avatar
Thumbs up
I'm thinking before vs after dyno tune using the SAFC-II.
191.74whp assuming a 25% drivetrain loss (5spd awd) = 255.6hp at the crank
Not to shabby at all. With a good driver and traction, he could probably get that thing down into the low 14's.
-Chike
P.S. It'll be interesting to see how the dyno numbers might have differed if he had used the Stage 2v5 from LAN...
Old 05-09-2006, 03:02 PM
victoria's car sure has been around.
Old 05-09-2006, 04:04 PM
+1
too bad it still has the body damage and fat lip...
Old 05-09-2006, 06:36 PM
immortal_suby's Avatar
Thread Killah
yeah kinda funny how he takes credit for all the upgrades Tom did.
on the dyno plot - how many other 5 speeds have been dynoed and how much of that gain is from going auto to manual?
Locker Link
2015 BRZ Limited 6MT
Old 05-09-2006, 07:35 PM
Chiketkd's Avatar
Phil (PhastSVX) dyno'd his 5spd SVX right before starting the turbo install. I think he made around 184-185whp. His car had the stage 2 software but didn't have the cams. Tom's old car has cams, but an SAFC-II instead of the stage 2.
