Old 04-29-2006, 03:08 AM
berger's Avatar
berger berger is offline
Send a message via ICQ to berger
svx in a forrester?
Hey, proberly wrong forum, but jsut curious
will the svx engine fit in other subaru's, like an 03 forrester?
Old 04-29-2006, 03:12 AM
Highly unlikey. I doubt there is enough space in any direction.
Old 04-29-2006, 06:47 AM
Manarius's Avatar
Manarius Manarius is offline
Umm. Well, the EG33 is "technically" a EJ series engine, so the mounts would probably line up. Now, you'd probably have to do a little bit of engine bay modification. I do have to say though, I've seen an EG33 in a BC (a 90-94 Legacy).
However, if you're really looking for a 6cyl in a Forester, probably would be better to go with EZ30. It's a little smaller and would be more likely to fit without any serious modification.
-Jason
-Obi Wan Kenobi
Old 04-29-2006, 06:48 AM
The Forester is based on the Impreza platform, and there have been EG33 transplanted into Imprezas before, the width isn't a problem, as it's no wider than a DOHC 4-Cylinder, but the radiator area IS a problem....
Old 04-29-2006, 08:48 AM
Manarius's Avatar
Yes, in the Legacy EG33 swap, the front frame had to be cut a little bit so that the radiator and fans would fit.
-Jason
-Obi Wan Kenobi
Old 04-29-2006, 02:28 PM
Anything can be made to fit with modification. No question there, but as a straight drop in space for your engine complimenting accessories ie radiator, fans, is severely limited.
It probably can't be done without some cutting.
Old 04-29-2006, 07:43 PM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
Indeed, it has been fitted innto a gen 1 liberty over here, i think with a bit of effort a eg33 fozza isnt out of the question, ir to save the hastle just get a tribeca
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 04-29-2006, 08:07 PM
nipper nipper is offline
As my father used to say, with a torch and a hammer anything is possible . But the engine is longer, It has been done before, but the entire front end had to be modified to move the radiator forward.
nipper
Old 04-29-2006, 08:19 PM
The EZ30 out of the new Legacy, and Tribeca is a much smaller made 6-cylinder, that will fit in without too many problems...
