Old 04-25-2006, 12:13 PM
Green1995SVX
Do not use the factory trunk jack!
These horror stories have been posted on here before about how unsafe the svx's trunk jack is. They collapse all the time it seems, so much so, that it's earned the name "danger jack" around my household. Even so, I was switching the wheels from my sold black svx to our new white one, and only had one decent jack, so i decided to try my luck with the danger jack. Well, my luck ran out. The jack bent and collapsed under the weight of the SVX, and when it did, it flew up around and really messed up the fender.
Old 04-25-2006, 12:16 PM
At least it was the fender that already needed replacing...
Old 04-25-2006, 12:34 PM
Did you have the wheels chocked? Did the car shift and cause the collapse or did it just decide to crunch???
Old 04-25-2006, 12:45 PM
Green1995SVX
I'm not entirely sure what happened. My neighbor was doing the switch and I was in the other room when it actually happened.
Old 04-25-2006, 12:58 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Originally Posted by Green1995SVX
These horror stories have been posted on here before about how unsafe the svx's trunk jack is. The jack bent and collapsed under the weight of the SVX, and when it did, it flew up around and really messed up the fender.
Oh my gosh!!
I never knew that! I'm glad I've never tried to use one before.
Dude!! Bad break!!
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 04-25-2006, 01:01 PM
n00b on demand's Avatar
wow that really sucks man
DreamingOfSpeed's Avatar
DreamingOfSpeed DreamingOfSpeed is offline
Send a message via AIM to DreamingOfSpeed Send a message via MSN to DreamingOfSpeed Send a message via Yahoo to DreamingOfSpeed
Has anyone written to the NHTSA about the jacks? If they get enough complaints about them and any injuries they will do an investigation and recall if needed. I've read their complaint files about the SVX and i've never seen anything about the jack. I'll post a link later for those who want to complain.
I didnt know there was a problem with it. When we jack up my car i always worry b/c we use jacks that are rated for just under the weight of the svx. I thought using the trunk jack would be better b/c subaru designed if for the weight of a subaru! I think i'll just get another heavy duty jack for the the svx and pitch the trunk jack. (not like i'm ever going to need it to change the tire on the side of the road!)
Old 04-25-2006, 01:15 PM
Speedklix's Avatar
Locker Link Solution
I really hate the design of our jacks... but it really shouldn't "collapse" unless the jack was't 90 degrees to pavment. The car rolling slightly could put it at such an angle that the jack bent off to one side. (which i'm sure is why someone asked if the wheels where choked) It is like jack stands.. they can support a lot of vertical weight, but are usless on their side. But still... with a regular jack (even scissor) this would probably not be an issue.
Sorry to hear about your fender, hope the wheel was on and no one was injured.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 04-25-2006, 01:25 PM
AppStateSVX's Avatar
AppStateSVX AppStateSVX is offline
Mountaineer
Send a message via AIM to AppStateSVX
wow, good thing I never used the one off my old SVX, it was old and rusted anyways
1992 Midnight Black LS-L - Sold 3/3/06
1991 Toyota MR2 - Sold 11/27/07
1992 BMW 325i
- Tokicko Suspension
Old 04-25-2006, 01:32 PM
SubaSteevo's Avatar
No longer blue member
I had the same thing happen to me, ended up putting a little hole in the floor of my garage from where the rotor landed
-Steve
01' MSM Lexus IS300
Old 04-25-2006, 01:34 PM
mikecg's Avatar
mikecg mikecg is offline
Looks like a good start to a wide body SVX.
I'd be tracking down the designer to kill.
Old 04-25-2006, 01:48 PM
Yeah... ive had an SVX begin to fold on me from jacking up my silver parts car..
Ours might be the next participant in the "patches of mismatched pearl club"
Hopefully not....
Eh, that fender was b0rked anyway....
Old 04-25-2006, 01:56 PM
Green1995SVX
Same here. Nice little chunk out of my garage floor from the rotor.
Old 04-25-2006, 02:00 PM
Green1995SVX
I'm taking the car today to a shop that has some sort of electronic optical color matching so they can make the proper paint color for the car. Hopefully that will work. Already have a replacment fender.
Old 04-25-2006, 03:41 PM
Pure_Insanity8's Avatar
Pure_Insanity8 Pure_Insanity8 is offline
Send a message via ICQ to Pure_Insanity8 Send a message via AIM to Pure_Insanity8
On the bright side, at least you were pretty much ready to replace the fender already and you weren't under the car.
I wonder if it is just the way the jacks were designed for Subies in the '90's. I was changing the oil in my stepmother's Legacy wagon, using the emergency jack, and it popped out... while I was under it. That scared me so bad I almost pooped myself. I bet there weren't wheels chocks in place, I'm pretty sure they would have saved me a heart attack.
So, how many SVX's is this? It feels like you're trying to obtain as many as Earl, just not keeping the one you already have. 4th... 5th?
-Aaron
SVX: '92 Dark Teal 101k
'97 Legacy GT Wagon: dead
'99 Civic Si: daily driver... stolen and stripped with all my tools!
'92 Yamaha FZR 600: garage
2011 Jetta: Daily disappointment
