Old 05-01-2006, 04:59 PM
#1 there is no reason a tire on a stock SVX wheel should rub in the rear at all. ESPECIALLY while suspended. Secondly, maybe you should bring it back to the people who "rebuilt" it and laugh horendously in their faces. If you are leaving 30ft strips of rubber, you are also leaving your gear box with 30ft of I don't give a flying crap about my transferclutches in there.
Old 05-01-2006, 07:05 PM
The tires are oversized.
I have intended for a long time to go back to get info about what they did exactly, because they made it apparent they only do transmission work, and didn't give two ****s about my diffs and probably know little concerning the electronics.
He did get in a snide "It's just a Pathfinder transmission, it's not very tough so be easy on it" comment the day I picked it up.
But if you recall, back in late 04 I was still pretty SVX dumb and didn't know anything about any solenoids.
Summer 05 is when I burned out, but trust me I care way more now than I ever have. I drive sensible and try not to damage anything or let people I don't know work on the car.
Old 05-01-2006, 07:39 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Send a message via AIM to gest24
This sounds pretty much like what was encountered Sat on the dyno. The rear wheels wouldn't do anything till the dyno laoded the fronts more. My only question is, why would a 96 SVX have no issue and my 92 have an issue?
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs!
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
88 XT6(regret the day I left her behind)
socaleuro.com They like the flat 6...
Check My New Homepage..
Old 05-01-2006, 11:51 PM
maybe your TPS is out of adjustment?? Just a thought. I think everyone should test their TPS voltage regularly, it is the most simple test once you have installed a lead.
Old 05-02-2006, 01:25 PM
That is one of my recent objectives. I've been around looking for a good cheap multimeter but could never find one.
I think I know someone who has one so I'll see if I can figure it out this weekend.
