Old 04-29-2006, 06:24 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Send a message via AIM to gest24
Dyno Flop
So today was the dyno day I've been waiting for since last month. We dynoed an OBD II SVX stock. She only pulled 128hp, kinda low for even stock. Then we put my Pearlie on the dyno. The shop owner started her up to get the car adjusted on the dyno. Then we find out that the rear wheels aren't always engaged and only engage when the front wheels slip. So pretty much I'm not 100% on how to put it into FWD mode so we weren't able to dyno mine. I'm just curious why the OBD IIs AWD system would act differently that the OBD I. Guess I jsut have to wait till I get the 6MT put in to Dyno.
Not mine, the stocker.
San Diego Mini Meet.
Final Results.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs!
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
88 XT6(regret the day I left her behind)
socaleuro.com They like the flat 6...
Check My New Homepage..
Old 04-29-2006, 07:23 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Okay, either the dyno was out of calibration or there's something wrong with your stock SVX. How many miles are on it? What gear did they have the trans in? You should have seen something more like 150-160 hp.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-29-2006, 07:32 PM
intelisevil's Avatar
<<<Alcyone
SVXi are NOT handicapped . . .
Dan
Old 04-29-2006, 08:08 PM
gest24's Avatar
#1 6MT In Cali
-Bill
She had a really bad oil leak and 100K+ miles. The tranny was in 3rd I beleive. Thats why I was really hoping to get mine the dyno and give the SVX some credibility back.
RIP
84 VW Scirocco
02 WRX
Old 04-29-2006, 10:03 PM
SVXRide's Avatar
The oil leak shouldn't result in a hp drop like you saw. You might want to get a Select Monitor hooked up to it to make sure your knock sensors are okay (bad ones can pull back timing, thus a loss of power). When was the last time the plugs were changed? Did the dyno operator record A/F during the run?
-Bill
p.s. a slipping trans will kill you on the dyno....
Old 04-30-2006, 12:59 AM
Duckie Duckie is offline
Send a message via AIM to Duckie
Actually on a mustang dyno that wouldnt be all that low for an SVX of that mileage...a local one pulled 126awhp
Old 04-30-2006, 06:36 AM
gest24's Avatar
#1 6MT In Cali
-Bill
The owner did get the AFR but I didn't get to see it. As for the maintenance of the car, I couldn't tell you what she's done to it. But the operator did say it felt like the tranny was slipping.
RIP
84 VW Scirocco
02 WRX
Old 05-01-2006, 04:06 PM
AvPPoW AvPPoW is offline
He lives in CA.... *cough*emissions*cough*
Old 05-01-2006, 06:25 PM
gest24's Avatar
#1 6MT In Cali
Not so much with mine tho... ;-) It was originally an AZ car. I'm sure after the mods I've done it's not smog legal anymore.
RIP
84 VW Scirocco
02 WRX
