Help!!
Hey guys
Today, after driving for about 3 minutes, I stopped and went to make a u-turn. When i did this the power steering stopped working, and the whole dash board (steering light/check engine/etc.) all lit up and then went away again. I have a had a power steering leak for a month or so, but it has never gone empty. I replaced the o-ring but that did nothing. I think it may be in one of the lines. I am just curious as to if anyone has ever had this happen? And what would the flashing of the lights indicate? I checked the fluid in the pump and it seems to be at a good level (I topped it off just for safe measure.) I have turned off the car, and left it for about 2 hours, started it up and turned the wheel (while stationary) and the same thing happened - power steering cuts out and the dash board lights up. Any suggestions would be appreciated. thanks Jonesy |
Thats unless the crank pulley is separating. Harvey.
I think Harvey is right, but if not,
Looooow powa. Happens to me once every blue moon. My accessory belt is tight so that's not my issue, but it's worth checking for you. If that's not the case get your battery and alt tested for load capacity as either may be crudding out. SVX alternators are somewhat notable for having no balls at very low rpms. --- Telltale signs to help diagnose are belt squeal, and does this happen only while turning, and if so does it only happen as the wheel is cranked all the way.
when i started the car the belt was squeaking, but then i started driving and it died down. Within 2 minutes was when the lights came on. And it is only when I am turning at a still, or very low speed. I am going to check the tension tommorow. thanks for the replies so far. Keep em coming!
If you had a PS leak, it could be on the belt and allows it to slip. If it is a hose, I would get it fixed asap. You could be down and out someplace or time you don't want to be.
