Old 07-19-2001, 07:02 PM
KEVINL
car has issues when cold
When I first start driving my car in the morning and its cold the car wont accelerate if you give it more than a 1/4 throttle it feels like it wants to stall if you let off it accelerates fine.
any ideas?
Thanks
Old 07-19-2001, 11:27 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: car has issues when cold
any ideas?
Thanks
You've cleaned your throttle body, right? Or, you may check out this TSB
http://members.tripod.com/adm/popup/...d561851ad8a2a8
Randy Johnson
Mike Davis -- at Reading VI
Old 07-20-2001, 09:49 AM
KEVINL
The throttle body is spotless
Old 07-25-2001, 11:29 AM
Lowered SVX
mine is doing this weird idling thing.
the rpm tach will just move between 1000rpm and 2000rpm and every now and then it will just die. but it cranks right up? in ideas?
"Too much fun to drive!"
Old 07-25-2001, 11:41 AM
sith
Leo - Thats what mine was doing for a while. My mechanic thinks it was the coolant temp sensor (thats the error code the ecu gave him), he replaced it and I haven't had starting issues since then. Maybe something to look into ... I think it was error code 21.. check out:
http://www.subaru-svx.net/archive/ar...?message=53511
