Old 03-06-2003, 04:56 PM
rbalach rbalach is offline
Unhappy HELP! Running rough from idle to 2500rpm
February 24th:
Drive home from work in hail,ice and sleet
February 25th:
City is shut down due to ice. Car was not used
February 26th:
Started car up, chipped off ice from glass, start driving. About a mile down the road engine starts running rough. Put shifter in N still running rough. Rough from idle to about 2500rpm. Check engine light came on for about 2min and then went out.
March 3rd - present:
Got appointment at Sub dealership. They pull codes, comes back with 2 bad injectors. Replaced injectors, still running rough. New code of bad coil. Replaced coil, runs ok in shop, take for test drive, starts running rough, pull codes, new code says different coil bad. Techs think ECU might be on its way out. They are not sure, they have placed a call into the Sub tech line.
Any ideas ? Thanks in adv guys.
RB
Old 03-06-2003, 05:10 PM
Boone
I'd certainly check/reseat the cables at the ECU.
