Why are you all wasting your time with this guy who is just screwing with you?
Obviously your only problem is you need to massage your buttwhacker valve before you blow a muffler bearing.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
It is definitely not a Canadian thing! Every country has one! Some have two! |
Check your blinker fluid. It may be low. If that's not the problem, check the simside solenoid on the turnerplot module. Seems to be a common problem on the Canadian spec models. Seems to have a direct corelation to Moose dander.
Aredubjay, you were right. I was low on headlight blinker fluid. My car handles alot better now, and the muffler bearing no longer makes noise. I tried to disable the cellular semiconductor so that my freeon grease cools my car more efficiently, but the steering wheel gasket got in the way.
Try replacing the gasket with a turken sleeve. That should free up the space you need.
Man, what don't you know!
Best wishes to you and your duty solenoids. |
what a crack head
Meanwhile, a pfitzer valve on the turken sleeve will add 20 horsepower by enhancing your nodel accelerator.
Thread Tools | |
Display Modes | |
