Old 01-28-2003, 12:10 PM
H6'er
Tps Issue?
Did search for "converter and unlocking"
Only saw two threads that seemed to match my problem but not much in way of conformation.......
Converter locks up normally in about 15min. of driving secondary roads but starts unlocking after another 15min. or so on highway.
Has been very cold, tranny temp dropping on highway or TPS?
Old 01-28-2003, 12:40 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Tps Issue?
Mine's been acting the same way. I "think" it's normal. First of all, the car won't even go into 4th gear until tranny temp has reached 50 degrees. TC Lockup occurs at 52 degrees (F). I'm not sure, but, I'm guessing that temp is the issue. It was 35 degrees this morning and things went back to "normal." In other words, I didn't have to drive five miles before 4th gear kicked in and I didn't have that "searching" feeling with the TC. Temps had been teens to single digits the past few days.
Anyone else?
Randy Johnson
Mike Davis -- at Reading VI
Old 01-28-2003, 04:15 PM
cbx-man cbx-man is offline
By chance does it happen with the cruise control on? My beater SVX would not hold the lock-up (except on ABSOLUTELY flat ground) using cruise control but was fine w/ cruise control off. Since my beater has a 5 spd now, the cruise control works fine... maybe TCU??? Just a guess.
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 01-28-2003, 04:20 PM
H6'er
Does it both with and without cruise on.
Need a good 50 degree day and a longer drive somewhere.
Old 01-28-2003, 04:23 PM
immortal_suby's Avatar
Thread Killah
I would bet it is just tranny temp - normal in cold weather if you have added an aftermarket tranny cooler and bypassed stock cooler. If you are running through the stock cooler then you do have a problem.
Locker Link
2015 BRZ Limited 6MT
Old 01-28-2003, 09:18 PM
Aredubjay's Avatar
Mine's running through the stock cooler, however, I have a new radiator (not the 92 with the mesh) and a Suby Rerman tranny that was put in about a year ago. Also, it was 44 degrees when I left work today. Didn't pull any of the "stunts" it had been pulling in the single and teens, temperatures.
Randy Johnson
Old 01-29-2003, 03:20 AM
Hot'n'cold
Guys
It is sure to be the temperature. Remember it is designed to do this to keep your ATF at the correct operating range. When lock-up drops off on the highway, it is bringing the Torque Convertor back into play. This will tend to add heat to the oil, in theory could bring it up to the value where lockup will happen again.
In practise, driving at low revs in a high gear on the highway, your cooler/s will be losing this extra heat to the low ambient at the rad, so you will not achieve lockup till the air temp rises enough.
Old 01-29-2003, 06:32 AM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
Yep, I have a cooler and notice that it unlocks the TC more often in the cold than in the warmer weather. I believe it's normal and the tranny is only trying to keep the ATF fluid at the proper temperature.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 01-29-2003, 09:26 AM
Aredubjay's Avatar
Yeah. What Joe and Mike said.
Of course, given that A) This is the first Autobox many of us have driven in years; B) The Suby Autobox has some unique characteristics that (probably) the last autobox we drove didn't have, and; C) SVX Transmission Horror Stories abound . . . you can't blame him for being just a tad bit paranoid.
Randy Johnson
Old 01-29-2003, 09:54 AM
H6'er
PARANOID?
ME?
I'm thinkin' about changing my middle NAME to "Paranoid"!!!!!
I REALLY do not want to drop another tranny in this thing....not unless I can $wing the 5speed.
Old 01-29-2003, 09:59 AM
Aredubjay's Avatar
PARANOID?
ME?
I've had to develop somewhat of a "comfort" philosophy: "Take care of her . . . drive her 'til she won't go no more . . . fix her . . . take care of her . . . drive her 'til she won't go no more . . . fix her . . . take care of her . . .
Randy Johnson
Old 01-29-2003, 11:02 AM
I'm lucky I have in excess of 500K miles of AT driving Only owned a stick for 6 months and 10K miles, and that was my XT6 with a 6 puck copper clutch and upgraded pressure plate.
-mike
Old 01-29-2003, 11:34 AM
Aredubjay's Avatar
-mike
I drove AT from 73 - 77. Then, stick from 77-99. There was a short stint from 77-99 that I drove AT occasionally in my Peugeot 505 STi, but, rarely.
Randy Johnson
Old 01-29-2003, 01:18 PM
kuoh kuoh is offline
I thought TC lockup was at 160F? I think the 50F is either second or third gear, depending on who's version of version of SVX gearing you subscribe to. Since adding the second tranny cooler, my TC never locks up when its below 40F outside, even after a 30 minute commute because the fluid temp never gets past 160F.
KuoH
Old 01-29-2003, 02:03 PM
Aredubjay's Avatar
KuoH
Perhaps the info I got from the service manual is wrong. I dunno.
Randy Johnson
