Old 01-16-2003, 10:25 AM
SHISVX SHISVX is offline
headlights
i find that my headlights aren't bright enough for my liking. my question is, i am putting aftermarket bulbs in. i think they take 50watt, would i do any harm if i put in 100watt bulbs?
Kelli
Previous owner of the
Princess Pearlie "Dimples"
as of 8/6/03
1992 LS-L Pearl 124k
"Yeah, that thingy!"
owner of the new 1992 LS-L Pearl "Susie"
I am a pessimistic optimistic. I think the worst is going to happen, that way when it does, i don't feel as bad, but if the best happens, i am twice as happy.
Old 01-16-2003, 11:46 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
You may so I would recommend getting an aftermarket harness like this one: http://suvlights.tripod.com/suvlight...re-harness.htm You could build you own, but the price is so low, I wouldn't bother to take the time.
It is really cheap insurance.
Also, make sure to aim your headlights properly after installing the new bulbs. With non stock bulbs, don't trust the bubble levels, use an aiming wall to properly aim the headlights.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 01-16-2003, 12:09 PM
BLKSVX92's Avatar
BLKSVX92 BLKSVX92 is offline
Casper Killer
Send a message via AIM to BLKSVX92 Send a message via Yahoo to BLKSVX92
my fogs are CATZ 130W output..ive had them in for about 4 years now.....no problems whatsoever
Michael
1992 SVX Build 4/91 SOLD TO gsodonis
2002 Civic Si SOLD
2005 Lancer Evolution VIII TRADED
2008 STi
Old 01-16-2003, 12:19 PM
Green1995SVX
This is from 95W "Nokya" bulbs... Please upgrade your harnesses.
http://www.subaru-svx.net/forum/atta...=&postid=71967
Mike
Old 01-16-2003, 12:48 PM
Mike isn't that damage from the ebay lights?? is it poss that all aftermarket lights would do that to it? little help here guys! these bulbs are expensive, i don't know anything about them, i have to ask the b/f for more detail, he bought me them for christmas
Kelli
as of 8/6/03
Old 01-16-2003, 12:54 PM
mohrds's Avatar
Just upgrade the harness. It will improve power delivery over the stock circuitry.
I made my own heavy duty harness before I found that site that sells them and I only run stock bulbs.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 01-16-2003, 11:38 PM
AbdominalSnoman
since his 95W bulbs could do that I can almost guarantee that 100W bulbs would do the same thing if they are both of the same types. (halogen with the same color temperature) This is assuming that his bulbs were really using 95W and yours will use 100W. There can be a good bit of variation. If his were designed to glow at a different color it will cause either more or less of the energy to be converted into heat. I believe the blue-er that the light is, the less energy goes into making the light and more goes into heat. (The most efficient lights would actually be pretty yellowish and the hottest ones being blue to purpleish.)
Old 01-17-2003, 09:37 AM
Noir's Avatar
Noir Noir is offline
the harness
will that harness listed above fit a 92 svx? it says on the site for subaru's 2000 or newer? if it won't fit, has anyone else upgraded their harness and who do they recommend. also anyone else tried using higher wattage bulbs (100w) and did they have problems with using those bulbs?
Old 01-17-2003, 10:29 AM
cjoffe
I'm thinking of getting the harness as well. My impression was to use the generic 9006/9005 harness. I wonder why they don't do one for the H3's.
CJ
Old 01-17-2003, 11:22 AM
mohrds's Avatar
CJ
Yes, get the generic harness. That has more than enough wire to span the radiator support.
The reason they do not make an H3 kit is that the H3 bulb is a 1 wire bulb. It grounds through the mounting base. Since every mounting base is attached and grounded differently from manufacturer to manufacturer, they wouldn't be able to put on the right ground harness to match every vehicle design. You could easily get a different kit, cut the socket off and add on high temp spade connectors to work with our H3 setup.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 01-18-2003, 02:30 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Would the Clear headlight covers from smallcar.com improve it? (when it comes out of course). Does anyone know how much that would run?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
