Old 01-06-2003, 03:10 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Front Diff
Are there any differences in the front diff on the transmission of a 91 Legacy and the 92 SVX besides the TC? PLEASE tell me NO!
Randy Johnson
Mike Davis -- at Reading VI
Old 01-06-2003, 04:53 PM
svx_commuter's Avatar
Oh what the heck. NO
Sounds like a good one for Huck.
Old 01-06-2003, 05:00 PM
lee lee is offline
you mean beside the gear ratio?
Old 01-06-2003, 05:55 PM
Randy, to use a Legacy front diff, you'll also have to use the Legacy Rear diff so the ratio's match..........I think you'd like it with the lower gears in the Evil Twin.
Old 01-07-2003, 10:08 AM
Huck, Are the housings for the differentials the same? I know from your prior posts the guts can be changed.
Old 01-07-2003, 10:26 AM
Aredubjay's Avatar
DARN! I still have the perfectly good (when it was taken out of the SVX) Legacy Tranny (From a '91 Legacy, rebuilt, less than 10K miles on it) Was hoping that the front diff would match and I'd just have to trade out the TC.
My problem is this: A bearing in the front diff has apparently gone "wonky" and is causing diff oil to leak into the tranny. I'm looking for a "cheap" fix instead of having to buy an entire NEW TRANNY! CRAP!
Randy Johnson
Old 01-07-2003, 02:43 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Are you certain it's not just the shaft seal in the front pump housing that's leaking? It would still require pulling the tranny and splitting the diff and pump housings.
Old 01-07-2003, 03:12 PM
Aredubjay's Avatar
Well, to quote the punchline from an old vaudeville routine, "Elephino."
Randy Johnson
Old 01-07-2003, 03:53 PM
lee lee is offline
When I had mine rebuilt I was trying to get by on the cheap and questioned the rebuilder about the need/price of the front shaft seal. He said he would do the job without the seal but would offer no warrany as a result - and these guys know Subaru trannys - recognized it on sight, even when pulled out of the back of a Toyota. You (per my rebuilder again) should also replace the tube (don't know if that's part of the seal kit) as it can get distorted during removal. best of luck
Old 01-07-2003, 03:59 PM
Aredubjay's Avatar
Thanks lee. My quandry in all this is, "did the rebuilder do the seals when they rebuilt the tranny, and botch the job?" or, "Did they just not bother, thinking it 'looked' okay?" The tranny was rebuilt by an independent shop that really is not familiar with Suby trannies, but, I REALLY couldn't afford the 4,600.00 price tag the local dealership wanted to replace my tranny.
Randy Johnson
Old 01-07-2003, 04:47 PM
Yes the housings are the same, so you could swap the SVX front diff ring and pinion gears into the Legacy tranny, but I still say put the Legacy tranny in and get a Legacy rear diff, if you want I'll try to locate one for you.
Old 01-08-2003, 09:56 AM
Aredubjay's Avatar
Actually, I can't be certain of anything, since I'd have to pull the tranny and split the diff to find out.
The "scrubbing" sound that I've been hearing for more than a year (which has gotten louder since the gear oil seeped out), would tend to make me think it was the bearing you indicated to me earlier.
Guess I'm going to have to take it to a "specialist." But, since we have none in this neck of the woods, I'll have to settle for a transmission shop.
Randy Johnson
Old 01-08-2003, 12:44 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
randy,
My 5spd will be here within the next two weeks, if your gonna be looking for a diff im gonna be selling my old core on ebay. But if you need it its yours. I cant garuntee it, But it worked great for me. for one specifically i can probably help you out.
phil
Also im selling TCu, and resitor, and all shift solenoid cept second shift solenoid which is dead.
phil
~Phil
Old 01-08-2003, 12:47 PM
Aredubjay's Avatar
Originally posted by Phast SVX
randy,
My 5spd will be here within the next two weeks, if your gonna be looking for a diff im gonna be selling my old core on ebay. But if you are gonna be looking for one specifically i can probably help you out.
phil
phil
Thanks, Phil I'll keep that in mind. The tranny in question was an e-bay purchase. I was just thinking that it might be easier to pull the tranny and slap another diff on it, rather than have to try and rebuild it.
Need I express how jealous I am that you're gettin a five-speed? May you have a speedy recovery, so you can enjoy it.
Randy Johnson
Old 01-08-2003, 12:53 PM
Phast SVX's Avatar
to tell you the truth randy, i wouldnt feel bad about just selling you the front diff. I cant imagine that there is a market for the actual gear box which is slipping. let me know.
PS thanks alot, im feeling a lot better its just quite swollen. Im very excited for the 5 speed. I decided to pull out all the stops. I have a 2003 forestor with 4.11 diffs and has only 2600 miles on it!!!! Also went with ACT racing clutch and STi TRans mount. Boy oh boy do i dream about it every night!
phil
~Phil
