Old 08-28-2003, 07:06 PM
Chicane Chicane is offline
Anti-BS Vigilante
Any new words on this subject?
- Rob
Old 08-28-2003, 08:02 PM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
New Thought on Problem
Not withstanding the previous thought re the "rattling" sound, I have found a solution to a "loose" frontend. I found that the bolts securing the front suspension subframe to the car become loose - not loose, loose, but need tightening due to the rubber washer being compressed over time. The first time I tightened the bolts, some took as many as two full turns to tighten down. This applies to both the front end as well as the rear end suspension subframes. A WORD OF CAUTION: Do NOT over tighten. These bolts have a shoulder on them, and if one runs the bolt totally down (really compressing the rubber gromlet), one runs out of threads on the bolt and one can ring off the bolt. This was done on my car with an impact gun set too high. The problem: the bolt has it nut as part of the frame of the car. All of that has to be drilled out and a complete (hight strength) nut and bolt replace the old assembly.
BTW, the tightening of these suspension subframes really make a BIG difference in the way the car feels and handles. I also reduced front end noise bt tightening the subframe.
Again, just a thought...
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 08-29-2003, 01:40 PM
Anti-BS Vigilante
Where are these located exactly? I'd love to do this, but I guess I'm not real clear about which bolts you are talking about.
- Rob
Old 08-29-2003, 01:52 PM
newsvx's Avatar
Rob,
The suspension subframes are a separate structure (both front and rear) that bolts to the underside of the car. In the front, the steering sector and anti-roll bar sit in this subframe. On the front, as an example, there are two large bolts just behind the lower "A" arms and two just in front that afix the subframe to the body of the car.
If you have the car on the rack in the air, they are fairly easy to see. You'll need a long breaker bar to get good leverage to turn the bolts - or an air impact tool. Again, careful just how tight you try to get them. You DON'T want to ring the bolt off! Asolution is to remove the bolts and add some washers to back the bolt up from the shoulder and to insure you have threads to work with.
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
