Old 12-18-2002, 03:50 PM
mbtoloczko's Avatar
sans SVX
front seat removal and SRS?
Chilton's manual says I should disable the SRS system before removing the front seats, but I see no sensors or electrical wiring between the seats and the SRS system, so I'm wondering if its really necessary. Can anyone let me know if the SRS system really needs to be disabled?
Thanks,
Mychailo
Visit my locker
Old 12-18-2002, 04:34 PM
svx6595 svx6595 is offline
Send a message via AIM to svx6595
I have taken the seats out of two SVX's without incident so I believe that disabling the SRS system is definitely unecessary.
Larry
Old 12-18-2002, 04:36 PM
immortal_suby's Avatar
Thread Killah
Same here - 2 different 92's I have removed front seats without problem - though I may have just been lucky.
Locker Link
2015 BRZ Limited 6MT
Old 12-18-2002, 04:47 PM
Joe 90's Avatar
Joe 90 Joe 90 is offline
Canadian eh!
I also removed my seats (a few times) on my 94.... No SRS wires attached to the seat. Just make sure you disconnect the wire for the motors AND the heated seat (if equipped).
Oh, one more thing, the drivers seat is PRETTY HEAVY....!
Good luck!
Joe 90
1994 Dark Teal SVX With real HID & Small Car Shift Kit (310000 km and counting)
Old 12-18-2002, 04:55 PM
mbtoloczko's Avatar
sans SVX
Thanks for the quick replies!
Mychailo
Visit my locker
