Old 10-24-2002, 07:24 AM
Alcyone SVX LSL
Question Codes......Please help. Need info asap!
Ok i read a post about getting the codes from the car. but what was described doesnt match up with what i have.
I have:
2 blue wired with male pins.
1 blue/white with female connector
1 yellow block connection w/ 6 wires (brown/red, brown/white, green/red, blue/yellow, black/red, red/green)
this is on a 92 behind the driver's side kick panel.
What should i do to recover the codes?
Thanx in advance..
Old 10-24-2002, 10:52 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Hope you can open a Word doc
Old 10-24-2002, 06:07 PM
Alcyone SVX LSL
Thanx Beav, no one informed me there were 2 in there, the black block was hiding from me behind everything. Got it all worked out, the coolant temp sensor was the problem as i thought, new one on the way.
Is it hard to install the coolant temp sensor???
