Old 10-17-2017, 05:16 PM
monkeyposeur monkeyposeur is offline
JDM VTD Transmission - Questions
Hello everyone, this is my first post on this forum. Although I am a fan of SVXs I don't own one. I've come across quite a few out here in Utah.
I own a few Subarus and I do all my own work. I have a Bugeye with a built hybrid motor 350 whp @ 4250 ft 91 octane, and an almost stock 93 SS Turbo legacy w/4EAT.
I built the SS for my wife and she won't let me swap in a 5MT because she loves having an automatic. The 4EAT has about 180k on it. Seems to run fine although I had to change out the Duty C solenoid a while back, and the problem didn't go away until I swapped in an NA TCU. I did a lot of diagnostics and couldn't figure out what the problem was.
Anyway, I am going to do a Robtune on her car soon and I was looking at some JDM 20G engine/trans combos that are pretty damn cheap. Since her trans is up in miles it would be nice to have a cheap backup available to swap in. I could use the 20g heads and get quite a bump in power as well.
My main question is regarding the JDM TCU. Does anyone know where to find one that will work with the 93-94 JDM EJ20G (VTD I think) auto transmission TCU. Trans code: TZ102YB3AA. Or does anyone know the part number or the 2 letter designation on the case?
Or has anyone come across any info on swapping in a later phase II 4EAT from an 02/03 WRX? I understand that it would involve swapping over some wiring, but I don't know how or if the stock ECU would need to communicate with the phase II TCU or if it is even possible.
Thanks!
Old 10-18-2017, 06:54 AM
92 SVX 92 SVX is offline
Re: JDM VTD Transmission - Questions
Thanks!
The newer transmissions are phase 2 and while technically it is possible to swap in the wiring is a nightmare and probably not worth the time unless you can do the job yourself I recall a shop did the job but they put in so much time.
