Old 05-21-2015, 06:19 PM
elemgee elemgee is offline
O2 Sensor Problem
My 94 SVX check engine light came on, and it was showing codes 32 (right hand side O2 sensor) and 37 (left had side O2 sensor). So I replaced both sensors with the ones by NTK. But I'm still getting an intermittent CEL code 37. I removed the left hand side sensor, checked all connections and reinstalled, but am still getting a CEL code 37. Any ideas what the problem could be? Not sure that this relates to the issue, but I recently replaced my MAF sensor with a new one for a 97 Legacy. Could I just have a bad O2 sensor right out of the box?
Other than the CEL light the engine runs and sounds fine.
Thanks.
Larry
Old 05-22-2015, 11:01 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Re: O2 Sensor Problem
Check your timing. The belt may have jumped one or two teeth.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 05-23-2015, 06:28 AM
michael's Avatar
michael michael is offline
What Potholes ???
If it's running fine the timing should be ok. Did you reset the computer after replacing the sensors? Let it sit overnight with the battery disconnected.
Wanted: Steering Wheel
Old 05-23-2015, 08:38 AM
The maf is not correct. I know many people use them for short term or diagnosis purposes but until that is corrected it will be very hard to properly diagnose your O2 sensors.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 05-23-2015, 05:49 PM
Yes, I reset the engine codes. I installed the new O2 sensor today and the CEL light didn't come on during a 20 mile drive, but i need to put some more miles on it to be sure. Regarding the MAF sensor, I resoldered the old one and will reinstall it if the CEL light comes back on in the next few days.
