Old 03-03-2015, 02:17 PM
processengr's Avatar
Circuit to run radiator fans after shutdown to avoid heat soak?
Hi all,
Would like to add a circuit to run radiator fans after shutdown to avoid heat soaking the engine compartment wiring, etc. Has anyone here done this?
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 03-03-2015, 06:10 PM
gwynethh's Avatar
gwynethh gwynethh is offline
Re: Circuit to run radiator fans after shutdown to avoid heat soak?
Originally Posted by processengr View Post
Hi all,
A web search found this which someone used on a different car.
http://www.at-fairfax.com/P1786-ELK-960.htm
needs an activating button
http://www.naxja.org/forum/showthread.php?t=1004656
"Peace is the flower of justice."
Old 03-08-2015, 08:29 AM
I'm sure you would do well with a basic turbo timer. It will allow the engine to run at idle for a predetermined amount of time after the ignition is shut off. This will probably be a lot easier and more efficient
