Old 01-04-2015, 10:55 PM
Andrew P.'s Avatar
Andrew P. Andrew P. is offline
The Ebony ones are faster.
Starter relay question
My 92 LSL has started having the intermittent start problem.
I've read most of the threads on the relay mod and will do it when the weather permits.
I would like to know if the relay in question is the starter inhibit relay?
If so, does anyone have the oem part number for it?
Thanks.
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU.
77' IHC Scout SSII
Old 01-05-2015, 06:50 AM
Re: Starter relay question
It's just a regular relay, nothing special that you need part number. Should be able to tell your parts person you need a Bosch relay with five blades and be fine. You really only need four but the original has five.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 01-05-2015, 11:14 AM
This was posted about 4 years ago for the relay under the dash;Bosch part# 0332204150.
However Summit racing says it is unavailable and wants to replace it with Bosch Part # 0332209150
Old 01-24-2015, 07:47 AM
Andrew P.'s Avatar
Thanks.
Now I just have to make time to work on it.
77' IHC Scout SSII
Old 01-24-2015, 12:16 PM
michael's Avatar
michael michael is offline
What Potholes ???
It's not plug and play? Is there how-to?
Wanted: Steering Wheel
Old 01-24-2015, 05:03 PM
http://www.svxworldforums.com/view_t...=Starter+relay
This should help.
Really what you do is mount a relay
Remove the wire on the solenoid and hook to relay
Run a new wire from relay to where you just removed that wire from.
Add 12 volts to the relay.
Old 01-26-2015, 01:28 PM
Andrew P.'s Avatar
I just changed the one under the dash. I'll see how that works.
When I have more time I'll do the other mod.
77' IHC Scout SSII
Old 01-26-2015, 04:51 PM
major7venth's Avatar
major7venth major7venth is offline
M7
Installing a starter relay fixes it, as shown in the previous post.hopefully the pix will show up for you. If not send me a pm with your phone # and I'll send pix. Its a piece of cake. Some wire,the right connectors and a relay and all is better,in the meantime be sure battery is fully charged.
Old 01-26-2015, 05:31 PM
michael's Avatar
What Potholes ???
Now I'm confused, there are two relays? Does the one under the hood piggyback the one under the dash or bypass it. If the one under the dash is bad shouldn't one just replace it before adding another?
Old 01-26-2015, 05:52 PM
gwynethh's Avatar
gwynethh gwynethh is offline
The second (after market mod) relay ensures full battery voltage to the starter solenoid. The default wiring can result in less than enough voltage to pull in the solenoid. The mod fixes the "clickity click" problem.
"Peace is the flower of justice."
Old 01-26-2015, 06:43 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Check out my locker. You will see "starter relay bypass mode diagram"
Also check "fix the click click" you will see instructions and some photos of installations.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 01-27-2015, 09:26 AM
Andrew P.'s Avatar
Thanks guys.
77' IHC Scout SSII
